Thread Closed
differential equations - mixing problem
Share Thread
Feb11-07, 10:31 PM   #1
A room containing 1000 cubic feet of air is originally free of carbon monoxide. Beginning at time t=0 cigarette smoke containing 4 percent carbon monoxide is blown into the room at 0.1 ft^3/min, and the well-circulated mixture leaves the room at hte same rate. Find the time when the concentration of carbon monoxide in the room reaches 0.012 percent.
rate = rate in - rate out ?
the 4% carbon monoxide part is really throwing me off. i don't exactly know what to do with this number. but other than that, i should be alright.
CO enters : 0.04 x 0.1 OR 0.1, i'm not sure whether to factor in the 4% CO
CO leaves : 0.04 x 0.1 S(t)/1000 OR 0.1 s(t)/1000
i need to figure that part out.. after that, everything i can handle. can someone please help me with the 4% carbon monoxide part
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb11-07, 10:53 PM   #2
okay so i tried working it out with the 0.04 factored in as shown above... and at the end i get a ln -#, so i guess that is wrong.
so now i am doing it without the 0.04. if i do it without the 0.04, then i do not understand the concentration part. it says to find the time when conc is 0.012 %, so set c(t)=0.00012 OR shoudl i be factoring in 4% CO somewhere still. i am really confused
Feb11-07, 11:29 PM   #3
Recognitions:
Homework Helper Homework Help
Here's a hint: make M(t) be the quantity of carbon monoxide in the
room at any time and then the concentration is given by C(t)
= M(t)/1000.
Feb11-07, 11:38 PM   #4
i have used, s(t) = amount of CO
c(t)=s(t)/1000
so i have rate in as: 0.04 x 0.1
rate out: 0.1 s(t)/1000
i have modified my rate in and rate out from when i first posted the eq'n as i don't believe i have to add the 4% CO factor twice. tell me what you think now.
i have solved this ALL the way to plugging in C(t)
i plugged in c(t) as 1.2 x 10^-4
my eq'n is
c(t) = 4x 10^-10 (1-e^(1.0x10^-4)t)
so pluggin in c(t)
1.2 x 10^-4 = 4x 10^-10 (1-e^(1.0x10^-4)t)
solving for t
300000 = 1-e^(1.0x10^-4)t
299999 = -e^(1.0x10^-4)t
so.. once again. i am stuck.
Feb11-07, 11:47 PM   #5
here is all my work.
rate in: 0.04 x 0.01
rate out: 0.1 x s(t)/1000
s(0) = 0
s'(t) = 0.004 - 1.0x10^-4 s(t)
s'(t) + 1.0x10^-4 s(t) = 0.004
solving diff eq'n:
a(t) = 1.0x10^-4, b(t)=0.004
using formula: u(t) = exp(integ(a(t)dt))
u(t) = exp(integ(1.0x10^-4 dt))
u(t)=exp(1.0x10^-4 t)
using formula: d/dt (u(t) s(t) ) = u(t)b(t)
d/dt ( (e^(1.0x10^-4 t )) s(t) ) = (e^(1.0x10^-4 t)) x 0.004
(e^(1.0x10^-4 t )) s(t) = integ (0.004(e^(1.0x10^-4 t))dt)
(e^(1.0x10^-4 t )) s(t) = 0.004(1.0x10^-4)(e^(1.0x10^-4 t) + C
s(t) = [(4x10^-7) (e^(1.0x10^-4 t)) + C]/(e^(1.0x10^-4 t))]
s(t) = 4x10^-7 + Ce^(1.0x10^-4 t)
sub s(0)=0
0 = 4x10^-7 + C
C= -4x10^-7
so,
s(t)=(4x10^-7)(1-e^(1x10^-4 t))
c(t) = s(t)/1000
c(t) = (4x10^-10)(1-e^(1x10^-4 t))
find t when c(t) = 1.2 x 10^-4
1.2x10^-4 = (4x10^-10)(1-e^(1x10^-4 t))
300000 = 1-e^(1x10^-4 t)
299999 = -e^(1x10^-4 t)
stuck. any suggestions or any wrong steps???
Feb12-07, 12:32 AM   #6
Recognitions:
Use natural logarithm.
Feb12-07, 02:52 AM   #7
i end up ln-ing a negative..
Feb12-07, 05:56 PM   #8
can anyone find the mistake?
i have some help from the instructor as he said the percentage is percentage of the volume, so i guess that is the part that is wrong??? i'm not sure what he means by that.
Feb12-07, 09:07 PM   #9
Recognitions:
Quote by braindead101 View Post
Re-check your steps. I already told you the idea
[tex] \frac{dm(t)}{dt} = 0.1 * 0.04 - 0.1 \frac{m(t)}{1000} [/tex]
Maybe you will have less mistakes in your calculations if you solved it like this.
[tex] c(t) = \frac{m(t)}{1000} [/tex]
[tex] 1000\frac{dc(t)}{dt} = 0.1 * 0.04 - 0.1 \frac{1000c(t)}{1000} [/tex]
Feb12-07, 09:13 PM   #10
Recognitions:
s(t) = 4x10^-7 + Ce^(-1.0x10^-4 t)
The mistake lies in these steps. You forgot the negative.
Feb12-07, 10:51 PM   #11
i'm working it out your way now, but the negative i 4got to type in, but i had it on paper and it doesnt really make a difference as when i am plugging in s(0)=0, c is still the same regardless of that.
Feb12-07, 11:05 PM   #12
Recognitions:
It DOES make a difference for the logarithm.
Feb13-07, 12:49 AM   #13
okay
so here is my work:
starting from pluggin in the concentration:
s(t) = (4x10^-7) - (4x10^-7)e^(-1.0x10^-4 t)
C(t) = s(t)/1000
c(t) = (4x10^-7)(1-e^(-1.0x10^-4 t)) / 1000
pluggin in c(t) = 1.2x10^-4
1.2x10^-4 = 4x10^-10(1-e^(-1.0x10^-4 t))
300000 = 1-e^(-1.0x10^-4 t)
299999 = -e^(-1.0x10^-4 t)
ln 299999 = ln -e^(-1.0x10^-4 t)
i am stuck agian..
at the same place
Feb13-07, 10:49 AM   #14
Recognitions:
Well i decided to do the problem to see why you weren't getting it right, anyway, i see another mistake, your integration is wrong. Btw, i get 30.05 as the answer, is t in minutes?, looks awfully fast if it was in seconds.
[tex] \int e^{kx} dx = \frac{1}{k} e^{kx} + C [/tex]
Feb13-07, 05:28 PM   #15
oh my god , thank you so much.
I have checked over my work so many timse and still did not catch that!
reworking my solution as we speak and hopefully i get the same answer as you.
Feb13-07, 05:36 PM   #16
i got the same answer as you, thanks very much.
Thread Closed
Similar discussions for: differential equations - mixing problem
Thread Forum Replies
confusing mixing problem - differential equations Calculus & Beyond Homework 4
differential equations - mixing problem (more complicated) Calculus & Beyond Homework 2
differential equations - logistic law problem Calculus & Beyond Homework 1
Differential Equations Problem Calculus & Beyond Homework 4
Differential Equations Problem Introductory Physics Homework 11
