MySQL: Logging SQL Statements for Debugging PHP Apps
  • Thread starter Thread starter rdx
    Mysql Sql
This discussion focuses on logging SQL statements into a MySQL table to aid in debugging PHP applications. The primary issue identified is the occurrence of MySQL syntax errors when attempting to insert values containing apostrophes. The solution provided involves doubling apostrophes in the SQL statements to prevent syntax errors during insertion. This method ensures that the SQL statements are correctly interpreted by MySQL, facilitating effective logging for debugging purposes.
  • Understanding of MySQL 8.0 syntax and error handling
  • Familiarity with PHP programming and debugging techniques
  • Knowledge of SQL INSERT statements
  • Basic concepts of logging and debugging in web applications
  • Research MySQL string escaping techniques for secure data handling
  • Learn about PHP error handling and logging best practices
  • Explore MySQL triggers for automated logging of SQL statements
  • Investigate the use of prepared statements in PHP to prevent SQL injection
PHP developers, database administrators, and anyone involved in debugging and optimizing MySQL interactions within web applications.
rdx
Goal: I seek to log the SQL statements into a MySQL table, with the time they were executed as an aid to debugging problems with PHP apps I am writing.
Problem: MySQL seems to try to interpret the statement, meant to simply be data in a field. When I try to "INSERT" the values, I get MySQL syntax errors.
Solution: Does anyone have a way around this problem?
Technology news on Phys.org
Do your inserts have apostrophes? You'll need to double them (replace ' with '').
Hmmm, I see what you mean.. I will look into it. Thanks.
12K
  • · Replies 16 ·
