Finding the Inverse of a Quadratic Function
  • Thread starter Thread starter unique_pavadrin
    Inverse
The discussion revolves around finding the inverse of the quadratic function f(x) = x² + 6x, with a specified domain. Participants explore the implications of the function's structure and the process of determining its inverse.
  • Participants discuss the correct formulation of the inverse by swapping variables and express confusion over handling the quadratic nature of the equation. There are attempts to clarify the steps involved in isolating y and solving for the inverse function.
The discussion is active, with various interpretations and approaches being explored. Some participants provide guidance on treating x as a constant in the context of solving the quadratic equation, while others express uncertainty about the implications of the domain and the correctness of their approaches.
There is a noted confusion regarding the domain specified as x ≥ -3 and x ≤ -3, which seems contradictory and prompts questions about its meaning. This may affect the interpretation of the function and its inverse.
unique_pavadrin
Hi
I need to find the inverse of the function [tex]f\left( x \right) = x^2 + 6x\[/tex] with the domain of [tex]x \ge - 3[/tex] and [tex]x \le - 3[/tex].
What i have done so far:
[tex] \begin{array}{c}<br /> f\left( x \right) = x^2 + 6x \\ <br /> x = y^2 + 6x \\ <br /> \end{array}[/tex]
and then from here I need to put the 2nd function in terms of y, however I do not know how to because of the function having the variable y twice. I am not asking for the answer of the problem, only suggestions on which way to approach the situation.
Many thanks
unique_pavadrin
Shouldn't your last equation be
[tex]y = x^2 + 6x[/tex]
and then you want to get equation x = some function of y?
[tex]x^2 + 6x - y = 0[/tex] is just a quadratic equation in x.
No No you don't just swap the x and y in one case, it must be all the cases.
so the [tex]f(x)=y=x^2 + 6x[/tex] Then [tex]x=y^2 + 6y[/tex] is your inverse.
I can't see any obvious ways to get y on its own from there.
>.< Well i thought what i said was correct, but if dexter says it isn't, then I am wrong for sure :). BUt yea I am pretty sure when you want the inverse, you change ALL the x's to ys and vice versa. in the OP the last bit of TEX was incorrect.
No, Gib Z, dextercioby's ? wasn't directed toward your saying that to find the inverse of y= x2+ 6x you start by changing it to x=y2+ 6y, it was toward "I can't see any obvious ways to get y on its own from there."
That's a quadratic function of y. You can always solve it by using the ____________.
Ahh I don't understand how the quadratic forumula would work >.<" Unless you mean take x to the other side and pretend its a constant? ...x=y(y+6)
Exactly. y^2 +6y-x=0 is a quadratic and should be solved for y(x) which is the inverse of the initial function, once one takes care of the domain issues.
ahh ok thanks for telling me that :) Didnt realize x could be treated like that. ty
Thanks for all the post people, your help is greatly appreciated. Sorry, wasn't able to get online until now due to isp problems. In my 1st post, the 2nd equation was a typo, it should have read x=y^2+6y.
So therefore the inverse of the function between the domain of [tex]x \ge - 3\,\,\,\,\,and\,\,\,\,\,x \le - 3[/tex] will be:
[tex]f^{ - 1} \left( x \right) = - 3 \pm \sqrt {36 - 4x}[/tex]
many thanks
The quadratic equation yields:
[tex]y(x)=\frac{-6 \pm \sqrt {36-4x}}{2}[/tex], which is definitely not what you have.
What does this domain mean? Is there a typo here; as it stands, this is equal to R
I get
[tex]y(x)=-3\pm \sqrt{9+x}[/tex]
ah i see where i have gone wrong.
thanks for the help, and sorry for any inconvenience
unique_pavadrin
dextercioby said:
I get
Well yea, that's after simplifications >.< I was still correct, technically :P.
Up to the minus sign under the square root, yeah...
>.< O jesus Christ shoot me
