How Do You Calculate Hall Voltage Across a Ribbon?
  • Context: Undergrad
  • Thread starter Thread starter aesopsowner
    Hall effect
The Hall voltage across a ribbon can be calculated using the Hall effect, which states that a potential difference is generated when an electric current flows through a conductor in a magnetic field. The formula for Hall voltage (Vhall) is Vhall = RH * I * w * B, where RH is the Hall coefficient in OHM*m/Tesla, I is the current, w is the width of the ribbon, and B is the magnetic field strength. Understanding the Hall coefficient is crucial for accurate calculations. Charge carriers, in this case, are assumed to be electrons (e-).
  • Understanding of the Hall effect
  • Familiarity with the concept of electric current
  • Knowledge of magnetic fields and their properties
  • Basic grasp of the Hall coefficient (RH)
  • Study the derivation of the Hall effect equations
  • Learn how to measure the Hall coefficient in different materials
  • Explore applications of Hall voltage in sensors and devices
  • Investigate the relationship between charge carriers and Hall voltage
Students and professionals in physics, electrical engineering, and materials science who are interested in understanding the Hall effect and its applications in measuring magnetic fields and charge carrier dynamics.
aesopsowner
Hey there.
Trying to figure out how to find a hall voltage across a ribbon. I'm given J, B, and some other factor: R-sub-h OHM*meter/tesla. (no clue what this is... :redface: )I'm also told to assume the charge carriers are e-'s. I understand that the hall effect is used to determine which charges are actually moving, but i can't really understand how the hall voltage is determined outside of V(hall) = q*width of ribbon*B.
I'm really not looking for an answer, but some general guidelines or tools that will help me solve the problem. Thanks in advance.
Hi there! The Hall voltage is determined by the Hall effect, which states that when an electric current passes through a conductor in the presence of a magnetic field, a potential difference is created across the conductor. In other words, the Hall voltage is the ratio between the electric current and the magnetic field. As for the R-sub-h OHM*meter/tesla, this is the Hall coefficient, which is used to calculate the Hall voltage. To find the Hall voltage, you need to multiply the Hall coefficient by the current, the width of the ribbon, and the magnetic field strength. Hope this helps!
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 21 ·
