Algebra Question: vector equations
  • Thread starter Thread starter Accurim
    Algebra Vector
The discussion focuses on finding the equation for the bisector of the angles between two lines, L1 and L2, represented by vector equations. The lines are defined as L1: r1 = (1,2) + T(6,1) and L2: r2 = (1,2) + K(4,3). The solution involves calculating the cosine of the angle between the direction vectors and establishing a relationship between the variables a and b, ultimately leading to the vector equation of the bisector line in the form of r_b = (1,2) + S(x,y), where the direction vector is the average of the direction vectors of L1 and L2.
  • Understanding of vector equations and their components
  • Knowledge of angle bisectors in geometry
  • Familiarity with dot products and vector magnitudes
  • Ability to manipulate algebraic equations
  • Study vector equations in detail, focusing on their geometric interpretations
  • Learn about angle bisectors and their properties in vector spaces
  • Explore the application of dot products in determining angles between vectors
  • Practice solving similar problems involving vector equations and bisectors
Students studying algebra and geometry, particularly those tackling vector equations and angle bisectors, as well as educators looking for examples to illustrate these concepts.
Accurim
The problem -
Consider lines L1 and L2:
L1: r1 = (X,Y) = (1,2) + T (6,1)
L2: r2 = (X,Y) = (1,2) + K (4,3)
Find an equation for either of the bisectors of the angles between L1 and L2
[tex]cos\alpha = \frac{(a,b)\bullet(4,3)}{\|(a,b)\|\|(4,3)\|}=\frac{(a,b)\bullet(6,1)}{\|(a,b)\|\|(6,1)\|}[/tex]
[tex]\frac{4a+3b}{5}=\frac{6a+b}{6}[/tex]
[tex]a=\frac{13}{6}b[/tex]
I'm not exactly sure what the question is asking, is there anything else I have to do?
Well, ||(6,1)|| is not 6. So what is (a,b)? You don't have an equation for a line yet.
Notice that both vectors go through the point P(1,2) so the position vector will also be [tex]\vec{p}(1,2)[/tex]. The vector equation of the bisector line will then be of the form
[tex]\vec{r_b} = (1,2) + S(x,y)[/tex]
The direction vector of [tex]r_b[/tex] will then be midway between the direction vectors of r1 and r2.
