Find Common Elements in Lists: SQL Query or PHP Nested Loops?
  • Thread starter Thread starter rdx
    Sql
The discussion revolves around finding common elements between two lists retrieved from SQL queries. Participants explore different methods to achieve this, including SQL queries and PHP nested loops, focusing on efficiency and effectiveness.
  • One participant presents a scenario where two SQL queries return lists of names, seeking the most efficient method to find common elements.
  • Another participant suggests using the SQL INTERSECT operator to find common names directly from the two queries.
  • A different participant proposes using an INNER JOIN to achieve the same result, specifying conditions for both the type and name.
  • A later reply mentions that the join method works well with MySQL, indicating a positive initial experience but noting the need for comparative statistics.
Participants present multiple approaches to the problem, with no consensus on the most efficient method. The discussion includes differing opinions on using SQL INTERSECT versus INNER JOIN.
Some participants do not specify the database management system being used, which may affect the applicability of certain methods. There is also a lack of detailed performance metrics to compare the suggested approaches.
Readers interested in SQL query optimization, database management, and programming efficiency may find the discussion relevant.
rdx
I get a list from a query. Let's say "SELECT name FROM foods WHERE type='fruit';" returns "apple, orange, banana"
I get a list from another query, "SELECT name FROM concepts WHERE type='color';" returns "red, orange, yellow"
Now what I want is to find the common element(s) in the two lists, in this case "orange."
What is the most efficient way to do this? SQL queries or PHP nested loops, or ?
Thanks.
Technology news on Phys.org
Code:
INTERSECT
I would have thought of using a join:
select f.name from foods f inner join concepts c on f.type = 'fruit' and f.name = c.name and c.type = 'color';
It works well with MySQL. It will be a while before I have comparative stats but this certainly works easily. Thanks.
14K
