Second derivatives using delta notation
The second derivative of a function f(x) can be expressed using delta notation as (f(x+h) - 2f(x) + f(x-h)) / h^2. This formula arises from the approximation of the first derivative, which is (f(x+h) - f(x-h)) / 2h. By further analyzing the change in the first derivative, one can derive the second derivative formula. Substituting g = 2h leads to the standard representation of the second derivative.
  • Understanding of calculus concepts, specifically derivatives
  • Familiarity with delta notation in mathematical expressions
  • Knowledge of limits and continuity in functions
  • Basic algebra skills for manipulating equations
  • Study the derivation of Taylor series and its relation to derivatives
  • Learn about numerical differentiation techniques
  • Explore the concept of higher-order derivatives
  • Investigate the applications of second derivatives in physics and engineering
Students studying calculus, mathematics educators, and anyone interested in deepening their understanding of derivatives and their applications in various fields.
bodensee9
Can some one explain why the second derivative of f(x) is (f(x+h)-2f(x)+f(x-h))/h^2? If you take the intervals to be x = 0 to x = 1 and you divide up the segment into little “hs” so that each x=h, 2h, 3h, nh, and so on?
I see that first derivatives can be approximated using (f(x+h)-f(x-h))/2h, but if you were to try to measure the change in (f(x+h)-f(x-h))/2h, wouldn't you get (f(x+2h)-f(x)-f(x)-f(x-2h))/2h^2?
Thanks.
No, you would get (f(x+2h)-f(x)-f(x)-f(x-2h))/4h^2
And if you substitute g = 2h you get the standard formula.
Another way to derive it is to use f''(x) is approximately (f'(x+h/2)-f'(x-h/2))/h and f'(x+h/2) is approximately (f(x+h)-f(x))/h
Oh I see it now. Thanks!
  • · Replies 17 ·
