How do these resitors not affect the voltage
  • Thread starter Thread starter snowJT
    Voltage
The discussion revolves around the role of resistors in a circuit and their impact on voltage and current, particularly in relation to a diode and a 2.2 k resistor. Participants explore the theoretical implications of resistor configurations, specifically in parallel arrangements, and how they influence circuit behavior.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions why the 6.8 k resistor and two 10 k resistors can be ignored when determining the voltage at the 2.2 k resistor and the current through the diode.
  • Another participant suggests that since the resistors are in parallel to the voltage source, they do not affect the voltage in the circuit unless their resistances are zero.
  • A different participant raises a concern that while the voltage may not be affected, the current through the circuit could still be influenced by the resistors.
  • One participant prompts a consideration of whether the current through the diode also passes through the resistors, indicating a potential relationship between current and resistance in the circuit.
  • Another participant introduces the idea of analyzing the circuit by removing the diode and examining the voltage across the 2.2 k resistor using the voltage divider formula to find the voltage drop and subsequently the current.
Participants express differing views on the impact of the resistors on voltage and current, indicating that the discussion remains unresolved with multiple competing perspectives on the role of resistors in the circuit.
There are assumptions regarding the configuration of the circuit and the specific values of the resistors that may influence the analysis. The discussion does not resolve how these factors interact in determining voltage and current.
snowJT
In this circuit... how come you just ignore the 6.8 k resistor, and the two 10k to find the voltage at the 2.2 to then get the current across the diode...
do not the 6.8 k resistor, and the two 10k have an effect on the circuit?
Since the resistors are connected in parallel to the voltage source, they do not affect the rest of the circuit voltage-wise (unless of course their resistances are set to 0).
but doesn't it affect the current? because that was what I was asking, not voltage
Well, you started by asking about voltage (correctly, since for this you need v=ir), but ask yourself this: does current going through the diode also go through those resistors?
You can also think of it this way. If you remove the diode from the circuit, you will have two terminals, A and B (across the 2.2K resistor). The voltage that the diode or any component will see when connected to these terminals will be the voltage drop across the 2.2K resistor. You can find the voltage drop across that resistor by using the voltage divider formula. And from here, you can go ahead to find the current.
  • · Replies 16 ·
