Unraveling the Mystery of Photon Motion: E=hf Explained
The discussion revolves around the nature of photon motion, particularly in relation to the equation E=hf, which connects energy and frequency. Participants explore the dual nature of photons as both particles and waves, the implications of their behavior in experiments, and the challenges of measurement in understanding their motion.
  • Some participants question how a photon moves and what is meant by its frequency in E=hf, suggesting that frequency relates to electromagnetic field oscillations.
  • Others propose that the dual nature of light implies photons may travel as point particles while exhibiting wave-like behavior.
  • A participant discusses the concept of superposition using a spring analogy, relating it to the measurement problem and the Copenhagen Interpretation.
  • There is mention of the photoelectric effect, Compton effect, and pair production as ways to understand photon interactions with matter.
  • Some participants express uncertainty about the implications of experiments like Young's double-slit experiment, noting that measurement seems to alter the behavior of photons.
  • Questions arise about the nature of pair production, with participants seeking clarification on the concept.
Participants generally agree that photons exhibit both wave-like and particle-like properties, but there is no consensus on how to interpret these behaviors or the implications of measurement on photon motion. Multiple competing views remain regarding the nature of photons and their interactions.
The discussion highlights limitations in understanding photon motion, particularly regarding the effects of measurement and the interpretation of experimental results. There are unresolved questions about the implications of wave-particle duality and the nature of superposition.
anantchowdhary
How does a photon move.If it is a particle and moves in a straight line,what do we mean by its frequency in
E=hf?
No one actually knows since we can't observe a photon without destroying it (i.e. in a photodetector). I'm sure this has been discussed somewhere recently, I'll have a dig around later and see what I can find.
E=hf?
The frequency is simply the frequency of the EM field oscillations, which determines the properties of light.
How do we get E=hf.And so u said that we don't know how a photon travels.its a part of the dual nature of light.So can't it be that the photon a point particle is traveling in sort of a wave?
What does the de broglie wavelength of a photon and of matter indicate?IS it the wavelength they would have if they were to be waves or sumthning like that?
That's a very good question but when you ask a physicist they won't give you a direct answer, personally i don't think they don't know the answer.Like if you ask a physicist about an electron's spin it doesn't actually mean that the electron's spinning its something totally different.They'll give you an quantum interpretation of the photon that they are particles of light E= hf the energy acquired by an electron (look at the photoelectric effect) now remembering that a photon can act as a particle or wave hv= quantum energy associated with an e.m wave of frequency v (think of it as a wave) . I wouldn't worry about it too much another way of getting a feel for the photon is by looking at how it also interacts in other situations such as the compton effect ( creation of x-rays) or in the scattering of electrons in a collission it is essentially radiation that is going to interact with matter in 3 primary ways via
1. the photoelectric effect
2.the compton effect
3. pair production
I hope i haven't bombed u with too much info. Hope this helps!
yes that is correct if they were waves
Imagine a simple demonstration: a silly spring(think Americans call them slinkys?) Someone is holding one end and someone the other, now one person introduces some movement at one end and the other person a different movement at the other, this is what superposition might look like of two states. We can see the spring moving in combination of these states.
Now if someone else knocks the spring from another angle we have another state, that's a wave in a 3 state superposition, there maybe many many states, perhaps even infinite states? Infinite different waves within the super position.
Now envision that someone comes along and measures the spring, now it behaves like a particle, so the act of measurement has destroyed all the superpositions of the spring or it has decohered.
Now how much does that reveal about what a photon looks like or how it propagates, given that we have a measurement issue.
This is the Copenhagen Interpretation in a nutshell.
And believe me it p's physicists off no end :smile:
EDIT: how would we know it travels in some sort of wavelike configuration? Young's two slit experiment shows it behaves like a wave producing band like patterns on the screen: as each photon passes through the slits, a sort of interference pattern builds up, of course if we try and detect the photon before it hits the screen, we end up with the photon merely striking the back of the screen as if it was a particle?
What do you think happens when a single photon is fired at the two slits? :smile: now what happens if we repeat this a thousand times?
pair production? what is that?
SO a photon is sometimes a wave and sometimes a particle moving in a STRAIGHT line.Have i got it correctly?
It appears from inference that it travels as a wave, as you will see when you look at the experiments below, but as soon as we try and measure it it appears to behave more like a particle losing whatever state it had, this is decoherence, we cannot really know what it looks like because the act of measurement destroys what we are trying to look at.
However since it produces interference patterns we infer it travels as a wave, as the back screen shows a dispersal pattern similar to a water wave.
I.e. If we used dyed the water you would see the same banding as the wave passed through the slits and the waves interfered with each other, this is a good analogy of what is happening.
These links will make it easier to understand
http://physicsweb.org/articles/world/15/9/1
http://physicsweb.org/articles/world/15/9/2
http://www.upscale.utoronto.ca/GeneralInterest/Harrison/DoubleSlit/DoubleSlit.html"
  • · Replies 33 ·
