Ghost Force(?) & Angular Momentum
The discussion centers around the relationship between angular momentum, torque, and the forces acting on celestial bodies, particularly the Earth in its orbit around the Sun. Participants explore concepts from classical mechanics, including Kepler's laws and the implications of changing angular speed and moment of inertia.
  • One participant asserts that the change in angular speed of Earth during its orbit implies an angular acceleration, which should be associated with a torque, raising the question of what force causes this acceleration.
  • Another participant argues that no external force is needed, as the conservation of angular momentum explains the phenomenon, drawing an analogy to a spinning person pulling in their arms.
  • A later reply questions the mathematical implications of angular acceleration without a corresponding force or torque, suggesting a misunderstanding of conservation laws.
  • Some participants discuss the fundamental nature of conservation laws in classical mechanics, suggesting that forces may not be as fundamental as these laws.
  • One participant introduces the concept of changing moment of inertia, explaining that torque can arise from variations in inertia rather than external forces.
  • Another participant emphasizes that gravity is a force acting on the orbiting body, questioning the exclusion of gravitational effects in the discussion.
Participants express differing views on the necessity of a force to explain angular acceleration, with some advocating for a force-free interpretation based on conservation laws, while others maintain that gravitational forces must be considered. The discussion remains unresolved, with multiple competing perspectives present.
Participants reference classical mechanics concepts such as torque, angular momentum, and moment of inertia, indicating a reliance on these principles without fully resolving the implications of their interplay in the context of gravitational forces.
yasar1967
From Kepler's second law as well as conservation of angular momentum, we know that Earth (any many other celestial objects) move faster when they get near the sun during their orbit and get slower when they are far away. This is a "change" in the angular speed so the derivative of it is a constant(if it's not a function). But this change must bring an angular acceleration α which in return brings us a torque due to the fact that
Torque= I x α = r x F
What is this force and where does it come from?
Sun's gravity is a central force and can act only parallel to the displacement vector from sun-to-earth thus it can't have any torque effect at all.
What force cause this acceleration of Earth during these phases?
There is no "force". This is the result of the conservation of angular momentum. It is the same effect that you get when you are spinning and bring your arms in. There's no external force or torque of any kind there.
Zz.
How would you explain the mathematical consequence then? a change in the angular speed thus an angular acceleration YET no force and no torque??
Mathematical consequence? What mathmatical consequence?
The conservation laws of our universe are not mathematically derived. It has no consequences to mathematics. The mathematical description of the conservation of angular momentum is pretty obvious, which I don't think is what you're asking.
Zz.
Thank you :)
What mathematics say that if there's a change in angular speed there MUST be an acceleration. If there's an acceleration there MUST be a force.
Yet you are saying that "that must not be" that's not how universe works.
Am I following you?
yasar1967 said:
Thank you :)
Am I following you?
Notice that when I wrote my response, I wrote the word "force" in quotes. I assumed that you know about external forces and torques that are missing from the system. This is the reason why the angular momentum of the system is conserved.
There is also something that you are missing. In classical mechanics, the "conservation laws" actually is the most fundamental aspect of the dynamics of any system. The "forces" are actually not that fundamental, and in fact, in the Lagrangian/Hamiltonian mechanics, forces don't even exist! This is because ALL you are actually detected are the two fundamental variables : the cannonical momentum and the cannonical coordinate positions.
So I don't quite understand the "obsession" with "forces" here in a system that really do not need such a thing when the application of a conservation law is sufficient and, in fact, simpler.
Zz.
It's not an obsession, if you're to think about it in classical terms you're prone to find a force to cause such acceleration.
But I guess this is where classical physics ends and "beyond" begins.
I'll think about a "forceless" universe and read Lagrangian/Hamiltonian mechanics.
Thank you, you opened my mind.
Classical physics does not end at angular momentum (in this context). Far from it. Perhaps http://www.lightandmatter.com/html_books/7cp/ch03/ch03.html can contribute to your understanding of angular momentum.
What happens is that the moment of inertia changes. And when that happens, [tex]\tau = I\alpha[/tex] is no longer good enough. We need to consider the more fundamental relationship [tex]\tau = \frac{dL}{dt}[/tex]. Since the angular momentum is given by [tex]L = I\omega[/tex], we can see that, in cases where I changes, torque is given by [tex]\tau = I\alpha + \frac{dI}{dt}\omega[/tex]. This means that there can be an angular acceleration without any external torque. You just need I to vary in time while the object is rotating; and, that's exactly what's happening here.
Ah, the perfect explanation! Since [itex]I=r^2m[/itex], zero external torque (in Parlyne's equation) implies [itex]\alpha = - \frac {2 \omega} {r} \frac {d r} {d t}[/itex], or in other words, unless there is a torque the planet has to decelerate (in terms of angular velocity) while-ever it is getting further from the sun ([itex]\frac {d r} {d t}[/itex] is +ve), and conversely a skater must spin faster if she draws in her arms.
Crystal clear... thank you!
Why can't we just say that the force here is gravity? If the orbit isn't circular, the object isn't traveling tangentiallly to the gravitational potential, so there is a force component in the direction of motion.
  • · Replies 16 ·
  • · Replies 40 ·
