Estimating B-Field Required to Levitate a Train
  • Context: Undergrad
  • Thread starter Thread starter peteboy rocket
    B-field Train
The discussion focuses on estimating the B-field required to levitate a train using electromagnets. The key takeaway is that it is not the B-field itself that is crucial, but rather the gradient of the B-field that influences the levitation of the train. The calculation involves comparing the magnetic energy density, defined as uB = B²/(2μ0), with the gravitational potential energy, UG = mgh, to determine if the gradient is sufficient for levitation. A model of the train as a long, skinny rectangular prism with a cylindrically radially uniform B-field is recommended for accurate estimation.
  • Understanding of magnetic energy density and its formula (uB = B²/(2μ0))
  • Knowledge of gravitational potential energy and its formula (UG = mgh)
  • Familiarity with the concept of magnetic field gradients
  • Basic principles of electromagnetism and train levitation systems
  • Research the principles of magnetic field gradients and their applications in levitation technology
  • Explore advanced electromagnet design techniques for optimized B-field generation
  • Study the physics of magnetic energy density in various materials
  • Investigate real-world applications of magnetic levitation in transportation systems
Engineers, physicists, and researchers interested in magnetic levitation technology, particularly those working on transportation systems and electromagnet design.
peteboy rocket
Hey!
I am trying to get a rough estimate for the B-field (from a electromagnet) required to levitate a train.
Assuming the train is of mass M, the force required to lift it and hold it at a distance D would have to equal M x g right?
But how do i estimate the b-field an electromagnet would have to generate to make this happen?
Thanks for any help!
Peteboy.:smile:
It isn't the B-field directly, but the gradient of the B-field that motivates ferromagnetic material (that isn't magnetized, as I'm assuming the train of interest is not magnetized). Then, the calculation basically involves the magnetic energy density just abolve the train, just inside the top of the train, just below the train, and just inside the bottom of the train. If the magnetic energy decreases by an amount greater than the gravitational potential energy increases for an upward displacement, then the gradient is sufficient to levitate the train.
I would suggest modelling the train by a long skinny rectangular prism, and approximate the B-field as cylindrically radially uniform (only an axial gradient).
Magnetic energy density:
uB = B2/(2μ0)
Gravitational potential energy:
UG = mgh
sorry for a late reply, but thanks! massive help.
Now just have to put in some guesstimate figures and come up with an estimate.
cheers,
peteBoy Rocket!
  • · Replies 22 ·
  • · Replies 20 ·
