Why does the earth have a core and can a planet exist without one?
The discussion revolves around the reasons for Earth's core formation and the possibility of planets existing without a core. It includes theoretical considerations, comparisons with other celestial bodies, and implications for planetary characteristics such as magnetic fields.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants suggest that a planet can exist without a core, citing the lack of a magnetic field in Earth's moon as an example.
  • Others argue that the Earth's core formed due to material differentiation during its formation, with dense iron sinking to create a core.
  • One participant notes that while the moon may not have a strong magnetic field, it likely has some form of core, as indicated by measurements of its moment of inertia.
  • There is a proposal that a planet could hypothetically lack a core if its material was well mixed and had sufficient internal energy to prevent differentiation, though this is considered unlikely.
  • Participants discuss the relationship between a planet's core and its magnetic field, with some stating that a core does not necessarily need to resemble Earth's core to exist.
  • Clarification is made regarding the definition of "core," specifically referring to a metallic core capable of generating a detectable magnetic field.
Participants express differing views on whether a planet can exist without a core, with some asserting it is possible under certain conditions while others emphasize the likelihood of cores in planetary formation.
There are unresolved assumptions regarding the definitions of "core" and the conditions under which a planet might exist without one. The discussion also highlights varying interpretations of the relationship between core composition and magnetic field generation.
verdigris
Why does the Earth have a core and can a planet exist without one?
Well, I know that Earth's moon has no magnetic field, which I'm fairly certain means that it has no core. If a planet had no core, then it wouldn't deflect the solar wind or charged particles. A planet can certainly exist without a core, but I wouldn't want to live on such a planet (at least not without SPF 10^23 sun block).
The Earth has a core because the materials differentiated during its formation, the dense iron crystallised out of the melt and sunk to the bottom. The density contrast at the core-mantle boundary (CMB) is rather high, in fact it is so high that g (the acceleration due to gravity) is greater at the CMB than it is at the surface!
I don't know that much about the moon but I'm pretty sure you'll find that it has some kind of core, core generally just means it has a concentrated centre of dense material. Measurements of the moons moment of inertia will constrain this, and similar measurements have been made of Jupiter's moons showing that they all have cores of some variety. All planets probably do have cores, as to whether they can exist without one, hypothetically yes, if the material was very well mixed and there was enough internal energy to prevent differentiation, but I don't see this as a physical likelihood.
Incidentally a core here does not necessarily have to resemble Earth's core!
The presence of a magnetic field is not necessarily related to the presence of a core, the Earth wouldn't have a (strong) magnetic field if its core was completely solid, unless it developed permanent magnetization which is of course quite possible below the Curie temp.
You're right Billiards. By "core," I was referring to a metallic core with enough angular momentum to produce a detectable magnetic field.
  • · Replies 42 ·
9K
  • · Replies 21 ·
  • · Replies 23 ·
