Which side of the triangle gives it maximu area?
  • Thread starter Thread starter MathLete
    Area Triangle
The discussion revolves around finding the length of the base of an isosceles triangle that maximizes its area, given two equal side lengths of 5 units each. Participants explore various geometric and mathematical concepts related to triangle area, including comparisons to squares and right triangles.
  • Participants discuss the relationship between the triangle's base and height, with some suggesting the use of trigonometric functions and calculus to derive formulas for area. Others question the implications of different triangle types on area maximization.
Multiple approaches to the problem are being explored, including geometric reasoning and calculus. Some participants have provided formulas and suggested methods for finding the maximum area, while others are clarifying concepts related to height and base relationships.
There is an emphasis on understanding the properties of triangles and their areas, with participants referencing specific calculations and diagrams. The original poster's initial assumptions about triangle types are being examined and challenged.
MathLete
For my homework (actually its a bonus question) I was given an isocelese triangle with 2 sides lengths defined. Let's call it triangle ABC.
Code:
    A
B         C
side AB is given 5 and side AC is also 5. I have to give BC a length for the triangle to have the maximum area.
First I thought of squares. A square has more area then a rectangle with the same parameter. 5x5 is greater than 1x20 thus proves my point of squares. I thought that If the triangle would be equalateral it would have the greatest area. But I was wrong after expirementing with numbers.
Then I thought since a square has the greatest area then half a square would be a triangle and therefore the right angle triangle should have the greatest area. Witch would have sqrt(50) as BC and an area of 12.5 according to my calculations (may be wrong).
Any thoughts on what kind of triangle will have the greatest area?
Can you write a formula for the area of the triangle in terms of the length of the base? That might suggest a way to find the maximum area...
I don't know what you mean by that. the area of a triangle is base times height divided by 2(bxh/2). You can use trig rations and sine/cos laws to find the height of the triangle.
Well do that then; find the height of the triangle in terms of the length of the base.
If you're lazy, you can use some trigonomery.
S=(1/2)bcSinA
Which angle has the biggest sine? pi/2 (+k2pi).
Just use some simple calculus (or cheat and just graph it on your calculator).
Look at this picture here
http://myfiles.dyndns.org/pictures/triangle1.jpg
Now based on that diagram I can make 2 formulas:
[tex]A = xy[/tex] since x is only half the base here
[tex]y = (5^2 - x^2)^\frac{1}{2}[/tex]
Combine them to get this
[tex]A = x(5^2 - x^2)^\frac{1}{2}[/tex]
Now differentiate it
[tex]\frac{dA}{dy} = (5^2 - x^2)^\frac{1}{2} - \frac{y^2}{(5^2 - x^2)^\frac{1}{2}}[/tex]
Make that formula equal to 0 and you get x.
Since my diagram had x as only HALF of the base length, double what you get for x.
I get the base as being 7.071 long. That gives the triangle and area of 12.5
S=(1/2)bcSinA
That gives the exact same area. (1/2)(5)(5) = 12.5
Give the teacher both answer and you might get extra bonus marks
This isn't that hard. Flip the triangle so that a given side is on the bottom. (Base) You know that the formula for area is base x height x 1/2.
Now pivot the other given side until you get the most height out of it. The base is given, you have the most height you can possibly get in ONE position only. Is this sinking in?
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 19 ·
