How to Calculate Current in a Coated Tube Connected to a Battery?
  • Thread starter Thread starter Soaring Crane
    Current Tube
The problem involves calculating the current flowing through a coated plastic tube connected to a battery. The tube is coated with a layer of silver, and the discussion centers around the electrical properties of the materials involved, specifically the resistance and current based on the dimensions and characteristics of the tube and coating.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of the cross-sectional area of the silver coating and the implications of the materials' properties (conductor vs. insulator). There are attempts to clarify the formula for resistance and the units involved. Some participants question the original poster's calculations and suggest re-evaluating certain aspects.
The discussion is active, with participants providing feedback on calculations and clarifying concepts. There is a mix of interpretations regarding the area calculation and resistance, and while some guidance has been offered, there is no explicit consensus on the final current value.
Participants are navigating through potential misunderstandings about the properties of silver and plastic, as well as the correct application of formulas in the context of the problem. The original poster expresses uncertainty, indicating that they are seeking clarification rather than a complete solution.
Soaring Crane
A plastic tube 25.0 m long and 4.00 cm in diameter is dipped into a silver solution, depositing a layer of silver 0.100 mm thick uniformly over the outer surface of the tube. If this coated tube is then connected across a 12.0-V battery, what will be the current?
R = (p*L)/A
V = I*R, where I = V/R
I’m a bit uncertain about this problem since there is both a semiconductor (Ag) and plastic involved.
A = 2*pi*(r1 + r2)*L – 2*pi*(r1)*L = 2*pi*r2* L = 2*pi*(0.100* 10^-3 m)*25 m = 0.0157 m^2?
R = (p_Ag*L)/A = [(1.47*10^-8 ohm*m)*(25 m)]/(0.0157 m^2) = 2.34*10^-5 ohm?
I = 12 V/(2.34*10^-5 m^2 ohm) = 5.129*10^5 A ?
If the above is incorrect, please direct me. Any help is appreciated.
Thanks.
1) Ag is not a semiconductor - it's a conductor. I would assume the plastic is an insulator.
2) A is the cross-sectional area of the silver coating. It doesn't involve L. I would rethink that part of the calculation.
3) The units for R are just ohms. Take another look at that line.
A = pi*(d + r)^2 - pi*r^2, where r is radius of insulator section and d is thickness of Ag layer
A = pi*[0.02 m + (0.1*10^-3 m)] - pi(0.02 m)^2
= 0.001269 m^2 - 0.001257 m^2
= 1.256*10^-5 m^2
R = [25 m*(1.47*10^-8 ohm*m)]/[1.256*10^5 m^2]
= 0.02952 ohm
I = (12 V)/(0.02952 ohm) = 410.2 A ?
Looks good to me!
  • · Replies 18 ·
