Recoil energy from neutrino question
  • Thread starter Thread starter Exulus
    Energy Neutrino
The discussion revolves around a problem involving the decay of an Ar37 atom through electron K capture into a Cl37 atom and a neutrino, along with a gamma ray emission. Participants are tasked with calculating the recoil energy of the Cl37 atom upon the emission of the neutrino, given specific energy values and mass differences.
  • The original poster attempts to calculate the Q value and apply linear momentum conservation but expresses confusion about how to proceed. Some participants question whether the X-ray emission has been considered in the calculations.
There is a note that the problem has been solved, with one participant indicating that the X-ray emission was not necessary for the solution. However, the details of the resolution are not fully explored in the discussion.
The original poster mentions a lack of clarity on how to approach the problem and expresses frustration over not reaching the expected answer. There is also a note about the need to format the post correctly, indicating potential constraints in the discussion format.
Exulus
Hi guys,
I've been struggling with this problem for a while now and can't seem to get anywhere with it. Roughly speaking:
We are given that an Ar37 atom decays through electron K capture into a Cl37 atom and a neutrino, plus a gamma ray of wavelength 4.2 Angstroms. The binding energy of the K capture is 3KeV and the mass difference between Ar37 and Cl37 is 816KeV. We've been asked to calculate the recoil energy of the Cl37 atom when the neutrino is emitted. We know the answer is 9.6eV but can't seem to get anywhere near it!
So far I've calculated the Q value to be 813KeV through the mass difference minus the binding energy of the captured electron. I've tried using linear momentum conservation knowing that the energy of the neutrino is E = pc. However, I can't even see how to begin.
Can anyone offer any starters? I've tried searching everywhere :( Thanks. I believe these are all the values we need to calculate it, but i am at a loss on what to do!
Hi guys (originally posted in the nuclear forum but since found this one),
[I realize this should be in a specific form but I'm literally about to go out right now, I will be back later and edit it if nessesary, thanks]
Have you taken the X-ray into account in your momentum conservation calculations?
Just want to say this has been solved now :)
Thanks. This has been solved now! Didn't need to take into account the x-ray emission. It was simply a case of using E = p^2/2m...doh!
  • · Replies 38 ·
  • · Replies 23 ·
