How Do You Calculate Electric Potential and Field for a Finite Line Charge?
The discussion focuses on calculating the electric potential (V) and electric field (E) for a finite line charge with linear charge density λ extending from -a to +a along the x-axis. The correct formula for electric potential is derived as V = Q/(4πε₀r) after substituting dQ = λdx. However, the user expresses uncertainty about the integration limits and whether λ should appear in the final expression. Additionally, the electric field can be determined using Gauss's law, followed by the relationship E = -dV/dr.
  • Understanding of electric potential and electric field concepts
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of Gauss's law and its applications
  • Basic understanding of linear charge density and its implications
  • Review the derivation of electric potential for continuous charge distributions
  • Learn about applying Gauss's law to find electric fields for symmetric charge distributions
  • Study the relationship between electric potential and electric field, specifically E = -dV/dr
  • Explore examples of finite line charges and their electric fields in textbooks or online resources
Students studying electromagnetism, physics educators, and anyone seeking to understand the principles of electric potential and fields related to line charges.
Brewer
A line charge has density λ and extends along the x-axis from -a to +a. Find the electric potential at a point r on the x-axis (r>a). Use your result to find the E-field at r.
[tex]V = \frac{1}{4\pi \epsilon _0}\int\frac{dq}{r}[/tex]
I've said so far:
dQ = λdx = Qdx/2a
Then I made the substitution into the above equation, and integrated wrt x with limits ±a, leaving me with [tex]\frac{Q}{4\pi \epsilon _0 r}[/tex].
However I'm not sure I made the correct integration here. I also believe that the answer for V should have λ in it somewhere. Have I gone wrong somewhere?
I haven't actually gotten round to looking at the E-field yet - I'll get there once this is completed!
Any pointers would be appreciated.
Thanks
Is this correct? I've spent my morning researching this, and I can't seem to find anything to compare it to - I'm a little confused as to what to do when the point is somewhere on the same line. Are my limits correct?
You could find the Electric field using gauss's law and then use E=-dV/dr to solve for V.
  • · Replies 18 ·
