Three symbols i can never understand in relativity tesbooks
  • Context: Graduate
  • Thread starter Thread starter Terilien
    Relativity Symbols
The discussion revolves around understanding specific symbols and concepts in relativity textbooks, particularly focusing on the Einstein summation convention, the upper case lambda with superscripts and subscripts, and the Kronecker delta. Participants seek clarification on these notations as they relate to tensor analysis and relativity.
  • One participant expresses confusion about the Einstein summation convention, asking for a clear and informal description with examples.
  • Another participant suggests looking up resources online, mentioning that the upper case lambda relates to the Lorentz transformation.
  • A participant claims the Kronecker delta is straightforward, contrasting it with the Dirac delta, which they find more challenging.
  • One reply explains the summation convention using an example, indicating how repeated indices imply summation over dimensions.
  • A participant provides a detailed explanation of the upper case lambda as a transformation matrix and illustrates its application in a specific example involving velocity.
  • Another participant raises a question about the tensor product, expressing frustration over its complexity and lack of motivation in explanations.
  • A later post discusses the tensor product's role in combining vector spaces and highlights its richer structure compared to simple addition of vector spaces.
  • One participant advises another to research topics independently to formulate more specific questions for better assistance.
Participants express varying levels of understanding regarding the discussed symbols and concepts, with no consensus on the clarity of explanations or the motivations behind certain mathematical constructs. Some participants find certain symbols easier to grasp than others, indicating a mix of agreement and disagreement on the complexity of the topics.
Limitations include varying levels of formal education among participants, which may affect their understanding of the discussed symbols. There is also an indication that some explanations may lack depth or motivation for certain mathematical concepts.
Terilien
There are three symbols in relativity textbooks that I've never encoutered before and need lots of help with.
1.Einstein summation convetion : Though not really a symbol i still don't quite understand what is meant by it.
2. Upper case lambda with super scripts and subscripts: It seems to be some sort of linear transformation, but I still don't quite understand it.
3. The great demon, the kronecker delta: I really cannot understand what is meant by this.
The reason I have such a hard time with this notation is because I have very little formal education.
However after the symbols are understood, it becomes very lucid.
Can someone please give me a CLEAR and informal description of what this means with examples relating to relativity and tensor analysis?
I'm very sorry.
I kinda tried http://www.mathphyswiki.com/index.php?title=Tensors" . If it's too brief, at least you have their names & you can look them up on google & wikipedia. I also included some texts on the main relativity page if you want to search through that.
#2 is the lorentz transform. I'd recommend waiting on that till you have the fundamentals down.
the kronecker delta is easy. even us bonehead enjuneers get that one. it's the dirac delta that's a b1tch.
The summation convention works like this. Whenever you see a lower/upper pair of indexes with the same letter, expand over the dimensions like so -
[tex]F^{\mu}F_{\mu} = F^{0}F_{0} + F^{1}F_{1} + F^{2}F_{2} + F^{3}F_{3}[/tex]
The Kroenecker delta is just the unit matrix written a different way.
In the unit matrix the elements I(i,j) are zero if i<>j and 1 if i=j.
So [tex]\delta_{ij}[/tex] is an element from the unit matrix.
I'm surprised you didn't ask about the Levi-Civita symbol [tex]\epsilon_{ijkl}[/tex]
The [itex]\Lambda[/itex] will take components in one frame to the components in another. The Einstein summation convention is to write a repeated upper and lower index out as a sum over the number of dimensions (as Mentz114 has said). I shall use both in the example below:
[tex]p^{a'} = \Lambda^{a'}\mbox{}_{a} p^{a} \equiv \sum_{a=0}^{a=3} \Lambda^{a'}\mbox{}_{a} p^{a} = \Lambda^{a'}\mbox{}_{0} p^{0} + \Lambda^{a'}\mbox{}_{1} p^{1} + \Lambda^{a'}\mbox{}_{2} p^{2} + \Lambda^{a'}\mbox{}_{3} p^{3}[/tex]
Assuming the transformation is along the x-axis of a velocity [itex]v[/itex] such that [itex]\beta = v/c, \gamma = (1-\beta^2)^{\frac{1}{2}}[/itex] the components of the transformation are
[tex]\Lambda^{a'}\mbox{}_{a}=\begin{bmatrix} \gamma&-\beta \gamma&0&0\\ -\beta \gamma&\gamma&0&0\\ 0&0&1&0\\ 0&0&0&1\\ \end{bmatrix}[/tex]
The Kronecker delta is the tensor form of the identity matrix:
[tex]\delta^a_b = \begin{cases} 1 & \mbox{if } a = b, \\ 0 & \mbox{if } a \ne b. \end{cases}[/tex]
As in: if you think of the indices labelling rows and columns of a matrix, only the entries along the main diagonal will be 1, and the off diagonal elements will all be 0.
There's one more thing I don't quite understand. what is the tensor product? why do we have it? why can EVERY m, l tensor be formed with it? That's what I've been having a real problem with. Everything else is pretty clear.
look I know I'm extremely stupid. no one has to rub it in.
EDIT: The rest makes a lot of sense now, but the darn tensor [product is just annoying.
It seems these days people don't care to list motivations for certain things.
Think what you can do with two vector spaces. You can add two vector spaces to make a new one, whose dimension is just the sum of the dimensions of the first two. The direct or tensor product is much richer.
When we multiply vector spaces, each element of a vector from the first field has associated with it an entire vector space, each being a copy of the second space in the product.
So the dimension is mxn, and the resulting object has 2 indexes.
http://en.wikipedia.org/wiki/Tensor_product
Small hint, Terilien. If you want better answers, google 'tensor product' or whatever you're stuck on, read a little & make an effort to understand it ... then ask more specific questions. People are more likely to help you with a difficult problem if they see you're making an effort.
  • · Replies 19 ·
  • · Replies 24 ·
15K
  • · Replies 26 ·
  • · Replies 67 ·
  • · Replies 41 ·
  • · Replies 18 ·
