Complex Analysis Proof of Constant Function
The problem involves proving that if a function f: ℂ → ℂ is analytic and the limit of f(z)/z as z approaches infinity is 0, then f must be a constant function. The discussion centers around the application of the Cauchy Integral Formula and the implications of limits in complex analysis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the Cauchy Integral Formula for the first derivative and the implications of showing that the integral is 0. There are attempts to analyze the behavior of f' at specific points and the limits involved in the proof.
The discussion is ongoing, with participants exploring different methods and questioning the validity of their approaches. Some have expressed uncertainty about the commutation of limits and integrals, while others are considering the boundedness of the function based on the given limit condition.
Participants note that their class has not covered the conditions under which limits and integrals commute, which adds to the complexity of their reasoning. There is also a recognition that the limit condition does not directly imply boundedness for all values of the function.
moo5003
Prove that if a function f:c->c is analytic and lim as z to infinity of f(z)/z = 0 that f is constant.
Cauchy Integral Formula for the first derivative (want to show this is 0 ie: constant)
f prime (z) = 1/(2ipi)*Integral over alpha (circle radius r) f(x)/(x-z)^2 dx.
So, I think I'm right in incorporating the cauchy integral formula for the first derivative into my proof. I hope that I can show that the integral over the closed curve is 0 for all z, meaning that 0 is the derivative of f and therefore f is constant.
Problems: Not sure how to show this integral is 0, since using this equation the new integral has a critical point over the point z. I'm assuming that the introduction of the assumption that the limit of f(z)/z = 0 needs to be employed to take care of this.
In other words, I believe I have equiped myself with the right tools, though I'm not sure how to start implamenting them, I'll update the post as I continue working on this problem though any help would be appreciated.
Hey, I think I may have gotten another method of solving the problem. Though when I took the limit I was a little unsure if I was allowed to say its 0.
Steps:
Since f is analytic its derivative is analytic.
f prime (0) = Lim z to 0 (f(z) - f(0))/(z-0) = Lim z to 0 (f(z)-f(0))/z
Taking the limit on both sides we get: (Lim assumes z to infinity, Lim' is z to 0)
Lim f'(0) = Lim' Lim f(z)/z - f(0)/z = Lim' Lim -f(0)/z
Lim f'(0) = Lim' Lim -f(0)/z
-Lim f(0)/z = 0 since f(0) is a fixed number.
Thus Lim f'(0) = Lim' 0 = 0
Since f'(z) is 0 at the origin and its domain (C) has an accumilation point (anything on the plane) the entire connected domain must also be 0. Because the entire domain is connected we can state that f'(z) is 0 everywhere and therefore the function f(z) is constant.
Edit: Nvm, I can see that I can't commute the limits like I did. :*(
Though, I may be able to use the same logic using the cauchy integral formula and show that the limit of the integral is 0 as x goes to infinity.
Question: Integrals and limits commute right?
Answer: That doesn't make sense.
It does make sense but is not necessarily true! The whole question of when limits (and the integral itself involves a limit) commute is a major part of analysis.
Our class hasnt covered (at all) cases in which limits and integrals commute (obviously by my question that is evident). Is the way I'm using *taking the limit of an integral* seem like the correct route to take or should I try finding another method to prove the claim. I'm a little lost on how to incorporate the limit of f(x)/x as x goes to infinity without taking the limit explicitley.
The only idea I have right now is to show that f(x)/(x-z)^2 is bounded for all x. Though I have no idea how I can do this without knowing f(x). I can try using the limit to prove that it must be bounded but again I'm unsure how to extrapolate this information.
Lim x to infinity of f(x)/x implies that for any epsilon > 0 I can find a S > 0 such that for all ABS(X) > S (Numbers outside the disk of radius S) it implies that ABS(f(x)/x) < Epsilon.
So... it doesn't really tell me anything is bounded, only that the complex numbers outside of a growing disk grow arbitrarly close to 0. It doesn't say that anything inside the disk namely f(0) is bounded by anything, nor does it state these facts about the actual function in question f(x)/(x-z)^2.
  • · Replies 17 ·
  • · Replies 16 ·
