Current Electricity: Help understanding concept of potential energy
The discussion revolves around the concept of potential energy in the context of electric charges, specifically focusing on how the potential energy changes as charges are manipulated in an electric field. Participants express confusion regarding the relationship between potential energy and electric potential, particularly when moving charges closer to or further from other charges.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the differences between potential energy and electric potential, questioning how potential energy can both increase and decrease under different conditions. There are attempts to clarify the implications of moving charges in an electric field and the associated work done.
The discussion is ongoing, with various interpretations being explored. Some participants have offered insights into the definitions of potential energy and electric potential, while others are still seeking clarity on specific points, particularly regarding the apparent contradictions in the statements about potential energy changes.
There is mention of a diagram that seems to contain conflicting statements about potential energy changes, which participants are trying to reconcile. The conversation reflects a mix of personal understanding and reliance on teacher explanations, indicating a learning process that is still in progress.
pugfug90
Current Electricity: Help understanding concept of "potential energy"
This is not a problem that I need help with. I rambled on and on for 5 minutes with teacher, eventually giving in and pretending that I understood..
http://i80.photobucket.com/albums/j199/pugfug90/CEPE.gif
Umm..
Perhaps I'm having more of a hard time than necessary because I keep thinking magnets when I see this diagram..
Basically, the diagram is representing a "situation" "as is".. When you manipulate the lower case +"q" to go towards +Q, PE increases, but PE decreases.. What? Or when you move +q away from Q-, PE increases but potential energy decreases? Too confused..
https://www.physicsforums.com/showthread.php?t=156815
PS Doc Al, I will post a follow up when I get my test back. Your method is easy enough that I'm sure I won't need your verification of your method:smile:
Assume the 2 large Qs are equal in magnitude. The potential along the vertical line equidistant from both charges is zero. It looks like q is on that line now. At a point to the left of that line, the +Q counts for more so the EPE of charge q is increased. At a point to the right of that line, the -Q counts for more so the EPE of charge q is decreased
If the +q charge is moved to the left, then the electric potential (voltage) at a point to the right is decreased because the +q charge is farther away. But the EPE of charge -Q is increased because the energy is less negative
Is there a difference between my teacher's "Potential Energy" and "PE"?
"the +Q counts for more"
"the -Q counts for more"
counts for more what?
EPE?
I still don't get why "Potential Energy decrease" yet "PE" (I'm assuming they're the same) increases..
I still don't get the left side, but I have a feeling the right side can be cleared up if you differentiate between potential and electric potential energy. Potential is voltage and does not depend on the charge in question (in this case -Q). V=sum of kq/r
EPE, however, does depend on the amount and sign of charge. It takes more work to lift a heavy object the same distance as a lighter one. EPE= QV = Q[sum of kq/r]. In this case, voltage is decreased but negative charges want voltage to increase. Therefore, the EPE is increased
No comprende..
I'll post more of today's notes..
"Potential difference is a measure of the magnitude of work required to move a charge from 1 point to another" (this was written before my diagram)
(After diagram)
"If charge is moved between these 2 points due to coulombic force of the force field acting upon it, work is done by the electric field and energy is removed from the system. However, if the charge is moved against the coulombic force of the field, work is done on it using energy from an outside source, storing the energy in the system"
"Therefore, potential difference (V) = Work (W)/Charge (q)"
"A volt is the potential difference between 2 points in an electric field requiring 1 joule of work to move a charge of one coulomb between these points"
This means that Work aka change in EPE = Vq
But you also need to know that voltage is equal to an electric field times the distance it acts over. V = Ed = kQ/d^2 * d = kQ/d. The potential at any point is the scalar sum of the potentials due to each charge. This makes adding voltages a lot easier than adding fields
The diagram you posted doesn't make sense to me. Usually PE stands for potential energy, in the diagram you have contradicting statements, if I am not drunk. Here we are talking about a specific type of PE- electric potential energy. Here is how I think about it.
Remember gravitational potential energy? If you push a ball up a hill, energy is stored in the ball. (really the ball Earth system, since if the Earth wasnt there there would be no potential, but anywho..)
You can imagine that the positive source charge is akin to a hill or mountain and the negative source charge is akin to a valley, of course this is in three dimensions so it is only an analogy. If the positive test charge moves towards the negative source charge, this is like a mass moving down into a valley- it loses potential energy. If the test charge moves towards the positive source charge, this is like a mass moving up a hill-it gains potential energy. Of course the test charge will not do this unless someone or something pushes it up the hill- work must be done by something. In a similar manner, if the test charge moves towards the negative test charge, something did work on it- here it is the field that is already in place due to the source charges.
The term potential, not potential energy, is like measuring the altitude of any position around the hill or valley. It describes the potential energy per unit charge ( or mass if we are talking gravitational potential, i.e. topographic map)
The weird thing is when you start looking at negative test charges since the field will "push them up potential hills."
Hope that helps. :bugeye:
Dear Jesus:bugeye: To think that I'll (maybe) have to take this when becoming a Biz major..
Forget all that other mumbo jumbo..
Please explain to me..
Why for both sides.. It says Potential Energy Decreases then says increases at the bottom.. Thanks:smile:
magnets aren't so bad a way of thinking about potential energy, at least in the case of repulsion. If you bring a pair of magnets together that are aligned to repel, the closer you get the two together before release the greater the action--in fact with weak magnets they might need to be almost on top of each other before showing any real interest in moving apart. Now for an attractive force in the everyday world, its less obvious. But consider a rock of 100 pounds. Dropped from an inch there's not a lot of potential energy waiting to be unleashed, drop it from an 8 story building on ones head, going to be a mess. So potential energy is like future profit potential. Its the potential to be a big deal. In some situations the closer the objects are, its greater, in others, further away. Physics is easier than economics in many ways. But if you want to succedd in biz, in the 21'st century and beyond the biz man who has a solid understanding of physics, engr and technology has a huge advantage over his/her less well educated colleague or competitor.
Thanks for the insight:)
So..
You diagram say (on the left) PE decreases... what is after that. The only statement that would make sense to follow the ... would be " as the charge is moved away from the positive point charge." On the right, after the ..., it would make sense if the diagram stated "if the charge moves towards the negative point charge."
hope that helps.
So..
It's confusing--the top statements are referring to the situation when the charges are free to move--whether be repelled apart or drawn together, in both cases the system loses PE to kinetic or some other form of energy.
Well that makes sense... So if they are naturally repelled or attracted, they lose potential energy..
But if I need power to puush + charges together, that gains PE, and if I try to disengage the attraction between - and +, that increases their PE?
Eh, kind of? Hopefully my teacher can clarify today..
Yeah kinda of
So.. my teacher said that "Potential Energy decrease" is when it's in the natural state of repulsion and attraction and the second bullet points are for "manipulation"...
Case closed?
I have no idea what you just stated??
Notice the diagram..
The top bullet points say "PE decreases"
The bottom contradicts..
My teacher is now saying that "PE decrease" is when the charge naturally goes where it wants to..
And that "PE increase" is when the +q is forced toward the +Q.
Okay that makes more sense.
Right, which is what I guessed what he was trying to say.
After all this is a build up to the topic of current flow. Charges will move if free to do so down a PE gradient and this we call electrical current.
  • · Replies 23 ·
  • · Replies 22 ·
