| Thread Closed |
metric/metric tensor? |
Share Thread |
| Feb21-07, 07:48 PM | #1 |
I'm having some troubles with a very basic definition of the metric tensor.
The metric is defined as [tex]ds^2 =[f(x + dx, y+dy) - f(x,y)]^2 [/tex] However, I can't see how this is equal to [tex]\frac{\partial r} {\partial x} \frac{\partial r} {\partial x}dx^2 + 2 \frac{\partial r} {\partial x} \frac{\partial r} {\partial y}dxdy + \frac{\partial r} {\partial y} \frac{\partial r} {\partial y} dy^2[/tex] I can see it in the linear case, like when [tex]r = x+y[/tex] since [tex]ds^2 = dx^2 + 2 dxdy + dy^2[/tex] for example. But what if there is a non-linear relation, like [tex]f(x,y) = x^2 - y[/tex] it will produce terms like [tex]dx^4[/tex] ...(I think, anyway). Basically, what I'm asking is how do you calculate the metric tensor components [tex] g_{\alpha\beta}[/tex]? Are they just found by making assumptions in the curved space you are in?How do you calculate the metric tensor from the metric? |
| Feb21-07, 08:24 PM | #2 |
The quantity you have above doesn't look like anything I recognize. What you have ican be viewed as the equation of a surface, i.e. z = f(x,y). The ds is then the difference in height (delta z) of neighboring points. It does not represent the Euclidean distance between two points as I would recognize it. Can you tell us what this f(x,y) is an how its supposed to fit into the definition of a metric??? Best wishes Pete |
| Thread Closed |
Similar Threads for: metric/metric tensor?
| What different between covariant metric tensor and contravariant metric tensor | Differential Geometry | 3 | ||
| about the metric tensor | Special & General Relativity | 30 | ||
| Metric tensor | Differential Geometry | 3 | ||
| relationships among metric structure, metric tensor, special and general relativity | Special & General Relativity | 18 | ||
| What is the Physical Significance of the Metric Tensor of the Flat Metric? | General Physics | 6 | ||
