Sum of an infinitesimal variable
The discussion revolves around the mathematical treatment of summing infinitesimal variables, particularly in the context of probability distributions in statistical mechanics. Participants explore whether the sum of infinitesimals can be generally concluded to be zero and how this relates to the properties of probability distributions.
  • One participant suggests that the sum of infinitesimals, \(\sum_r dx_r\), could be zero because it involves summing a finite number of infinitesimals, contrasting it with integrals that sum infinitely many infinitesimals.
  • Another participant argues that the sum is not generally zero, clarifying that it is zero in the context of probabilities due to the normalization condition \(\sum_r p_r = 1\), which holds for probability distributions.
  • A different participant expresses skepticism about the concept of summing infinitesimals, questioning the validity of such an operation outside of non-standard analysis.
  • One participant acknowledges the clarification regarding the sum being zero due to the nature of probability distributions and discusses the relationship between differentials and sums in the context of mean energy calculations.
  • There is a mention of a shift in the index "r" from a finite to an infinite set, prompting further inquiry about the implications of this change on the sums being discussed.
Participants exhibit disagreement regarding the generality of summing infinitesimals and whether it can be concluded that such sums are zero. While some acknowledge the specific case of probabilities leading to a zero sum, others challenge the foundational understanding of summing infinitesimals.
There are unresolved questions about the treatment of infinitesimals and the conditions under which summing them is valid. The discussion also touches on the implications of changing the index from finite to infinite sets, which remains unclear.
Repetit
Hey!
Can it be concluded generally that:
[tex] \sum_r dx_r = 0[/tex]
...because we are summing an infinitesimaly small variable a finite number of times, in contrast to an integral which is an infinite sum of infinitesimaly small variables? In one of my books a probability is given by:
[tex] p_r = \frac{1}{Z} Exp[-\beta E_r][/tex]
... and in the next line they write that:
[tex] \sum_r dp_r = 0[/tex]
Does someone have an explanation to this?
Repetit,
No you are totally wrong. In general this is not zero.
It is zero in your example, because you are dealing with probabilities.
Remember that for any probability distribution we have:
[tex]\sum_r p_r = 1[/tex] (eq 1)
Assuming this sum extends over all possibilties, then this sum is a constant.
Therefore if you differentiate the probabilties, because for example a parameter of the problem changes (temperature for example for a velocity distribution in statistical thermodynamics), then the sum of all these variations must equal zero:
[tex]\sum_r dp_r = 0[/tex]
This is a consequence of (eq 1).
For example, if you increase the temperature, the higher energy states get more populated, but this happens at the expense of lower energys states populations, because the total of the population must remain constant.
I assumed you were studying statistical mechanics, but this is true in any case.
In statistical mechanics,
[tex]\beta = \frac{1}{kT}[/tex] is the reciprocal of the temperature T,
[tex]p_r[/tex] is the probability
that the state of energy [tex]E_r[/tex] is occupied,
and Z, the "partition function" is simply the normalisation factor of the distribution.
I hope you will enjoy,
Michel
Repetit said:
Hey!
I have never heard of "summing" a finite number of "infinitesmals". I can't imagine any good reason for doing so. Are you sure you are understanding the text correctly. Unless you are dealing with "non-standard" analysis you shouldn't even be talking about "infinitesmals" except as a shorthand for derivatives and integrals!
Sometimes probability text will do strange things but there should not be a "dp" without an integral connected!
Thanks for the answers to both of you. I see now that the sum must be zero because [tex]p_r[/tex] is a probability distribution. And lalbatros you were right, I am studying statistical mechanics.
HallsofIvy:
Yes it seems strange that summing differentials (what I called infinitesimals before, but isn't it the same?) can make any sense, but look at the following example:
[tex] E=\sum_r p_r E_r[/tex]
Where E is the mean energy. The differential element dE would then be given by:
[tex] dE=\sum_r p_r dE_r + \sum_r E_r dp_r[/tex]
I suppose that would be alright then? Sums of differentials are everywhere in the book and I'm pretty sure that I understand it correctly. It's the book Statistical Physics by F. Mandl page 84-85 if you want to check it for yourself.
By which "r" has now changed from being an index on a finite set, to an index on an infinite set.
Could you elaborate on that? Isn't there still a finite number of terms in the sum, and is r not still the same index variable indexing the (finite) number of energy levels?
  • · Replies 22 ·
  • · Replies 24 ·
  • · Replies 0 ·
