Electromagnetic induction and EMF in wire
The discussion revolves around electromagnetic induction and the behavior of induced electromotive force (emf) in a wire when it is moved through a magnetic field and subsequently stopped. Participants explore the implications of stopping the wire and the resulting movement of electrons within the wire.
  • Participants examine whether the induced emf remains when the wire is stopped and discuss the behavior of electrons as they redistribute. Questions arise about the forces acting on the electrons during this process and the implications of moving the wire out of the magnetic field.
The discussion is active, with participants providing insights and questioning the physical realism of certain scenarios. Some guidance is offered regarding the forces on electrons and the nature of induced emf, but multiple interpretations and uncertainties remain present.
Participants are navigating concepts related to electromagnetic induction, forces on charge carriers, and the redistribution of charge in a wire, while also considering the constraints of physical realism in their scenarios.
adamg
If you move a straight wire down through a magnet field, an emf is induced in the wire. If you then stop moving the wire, does the emf remain or does it disappear i.e do the electrons flow back? What about if you moved the wire out of the field?
The emf disappears. Yes, the electrons redistribute themselves along the wire.
Same thing. The emf is due to the magnetic force on the charge carriers (electrons) in the wire. That force is [itex]F = q \vec{v} \times \vec{B}[/itex]; stop the motion or remove the field and the force (and emf) goes away.
(Thanks for the help) When the electrons flow back along the wire, doesn't that produce a force? the force will be in the same direction that originally created the emf i.e down. This force down will create a force on the electrons pushing them back i.e as in the creation of the emf. Is that correct?
The only possibility i could think up was that the final force mentioned above is not large enough to prevent the electrons flowing back to their original position??
Is this what you mean. If the wire is stopped, will the charges moving back experience a force since they are moving in a magnetic field?
If that's what you mean, the answer is yes. But what direction is that force? It is not along the wire (like the emf was), it is sideways to it.
Let me know if I am missing your point.
When the wire is being moved down, the electrons accumulate at one end. When you stop the wire, the electrons move back. Using left hand, this creates a force down. So force on electrons is down, so wire will move down. This constitutes a current going up and the force created will try to push the electrons back (as when the wire was being moved down originally) But obviously the electrons continue to move back to their original position, so this final force must be smaller than the force created due to the emf between the ends of the wire. (?)
I think I understand your question now. Very interesting. It's difficult to answer, since I don't think it is physically realistic. (Perhaps I'm just confused!) As you slow the wire down, the moving charges will create a force pushing down---this force opposes your attempt to slow the wire. But the charge redistributes very quickly. If you could somehow stop the wire before the charge had a chance to move (not possible, I think) then I suppose the moving charge would create a movement of the wire and thus another induced emf (opposing the motion of the charge). But, yes, this would be a smaller emf (the emf depends on the speed of the wire). (I think energy conservation would be violated if it weren't.)
Oh, i think i understand. The charge starts to re-distribute when you start slowing it down, since the force on the electrons reduces, so by the time you actually stop it is already back in its starting position. Is that correct? Then, yes, my scenario is impossible i think.
Yes, that's the idea.
  • · Replies 0 ·
