Sum of Power Series Homework: Show Convergence and Determine Sum
The discussion revolves around the convergence of the power series \(\sum_{k=1}^{\infty} \frac{x^{2k+1}}{k(2k+1)}\) and the determination of its sum, particularly for \(|x| < 1\). Participants are exploring the conditions under which the series converges uniformly for \(|x| \leq 1\).
  • Participants discuss using the Weierstrass majorant principle to show uniform convergence and question the applicability of the ratio test for uniform convergence. There are attempts to differentiate the series term by term to relate it to known Taylor series.
The discussion is active, with participants providing various approaches to understanding convergence and the sum of the series. Some participants suggest calculating specific terms and manipulating the series to identify a function that matches the series' Taylor expansion.
There are indications of confusion regarding terminology, such as the distinction between "sum" and "series." Additionally, some participants express uncertainty about the implications of absolute convergence on uniform convergence.
flybyme
Show that the power series [itex]\sum_{k=1}^{k=\infty} \frac{x^{2k+1}}{k(2k+1)}[/itex] converges uniformly when [itex]|x| \leq 1[/itex]and determine the sum (at least when [itex]|x| < 1[/itex]).
Couldn't I somehow go about and show that, as [itex]|x| \leq 1[/itex], then [itex]f = \frac{x^{2k+1}}{k(2k+1)} \leq \frac{1^{2k+1}}{k(2k+1)} = \frac{1}{k(2k+1)} = g < \frac{1}{2k^2}[/itex] which converges. Then by Weierstrass majorant principle f should converge. Or am I missing something? And how do I find this sum? :confused:
you should use the ratio test. where ever the limit evaluated by ratio test is less than one the series converges
It seems from the way you write your explanation you confuse the sum with the individual terms in the sum.
Anyway, missing some absolute values you have a handle on showing that terms are each bounded (in absolute value) uniformly in x as indicated.
To see what the sum is, what you get if you differentiated term by term?
You would have to manipulate factors and powers of x, but it reduces to using a Taylor series you know.
But if I use the ratio test, is a absolutely convergent sum also uniformly convergent?
More
That it converges is one thing. What sum of the infinite series turns out for x as indicated is another
I'm sorry but you're speaking in riddles for me... :blushing: :rolleyes:
These are excerpts from the question:
flybyme said:
...and determine the sum...
...And how do I find this sum? :confused:
Sorry, with "And how do I find this sum?" I was referring to the power series in section 1.
As far as I understand it I can't use the ratio test to show uniform convergence.
You certainly should know that if a power series converges absolutely on a set, then it converges uniformly on that set. See\
http://math.furman.edu/~dcs/courses/math39/lectures/lecture-39.pdf
He was just pointing out that you have two questions- where the series converges uniformly and what the sum is. It might help to remember that any power series is the Taylor's series for the function it converges to.
Here's what I would do. First calculate a few terms to see what is happening:
[tex]\frac{x^3}{3}+ \frac{x^5}{10}+ \frac{x^7}{21}+ \frac{x^9}{36}+\cdot\cdot\cdot + \frac{x^{2k+1}}{k(2k+1)}+ \cdot\cdot\cdot[/tex]
Factor out x3:
[tex]= x^3\left(\frac{1}{3}+ \frac{x^2}{10}+ \frac{x^4}{21}+ \frac{x^6}{36}+\cdot\cdot\cdot + \frac{x^{2(k-1)}}{k(2k+1)}+ \cdot\cdot\cdot\right)[/tex]
Write that as powers of x2:
[tex]= x^3\left(\frac{1}{3}+ \frac{x^2}{10}+ \frac{(x^2)^2}{21}+ \frac{(x^2)^3}{36}+\cdot\cdot\cdot + \frac{(x^2)^{k-1}}{k(2k+1)}+ \cdot\cdot\cdot\right)[/tex]
Can you think of a function that has Taylor's series
[tex]\frac{1}{3}+ \frac{x}{10}+ \frac{x^2}{21}+ \frac{x^3}{36}+\cdot\cdot\cdot + \frac{x^{k-1}}{k(2k+1)}+ \cdot\cdot\cdot[/tex]?
Ah... I totally missed that I had written "sum" instead of "series" in post #4. Guess this scheme of mine, trying to work full days and then brushing up on my math during the nights isn't going to well. I'm just too tired most of the time. My apologies.
Factor out x3:
Not really...
As in my previous installment, if you differentiated term by term (maybe more that once, if needed), you would arrive at a more familiar series. Then work backwards (integrate) so you get an explicit formula.
heh, you want to try to find some close form for the original series? just differentiate with respect to x! (it is quite obvious! come on!)
