| Thread Closed |
Calculating Square Roots - Matrix Algorithm |
Share Thread | Thread Tools |
| Feb23-07, 11:39 PM | #1 |
Hi. I only just recently found out about an algorithm for calculating the square roots of a number.
Lets say i want to evaluate [tex]\sqrt {n}[/tex]. I can make an approximation by inspection, and say [tex]\sqrt n \approx \frac{a}{b}[/tex]. Now, using this approximation, i can write: [tex] \left[ {\begin{array}{*{20}c} 1 & n \\ 1 & 1 \\ \end{array}} \right]\left[ {\begin{array}{*{20}c} a \\ b \\ \end{array}} \right] = \left[ {\begin{array}{*{20}c} {a + bn} \\ {a + b} \\ \end{array}} \right] [/tex] Treating the resultant matrix as a fraction ([tex] \frac{{a + bn}}{{a + b}} [/tex] ), i have a better approximation of [tex]\sqrt {n}[/tex]. If i keep repeating this method with the new approximation, over and over again, i get a more accurate answer. So the next step would be: [tex] \left[ {\begin{array}{*{20}c} 1 & n \\ 1 & 1 \\ \end{array}} \right]\left[ {\begin{array}{*{20}c} {a + bn} \\ {a + b} \\ \end{array}} \right] = \left[ {\begin{array}{*{20}c} {a + an + 2bn} \\ {2a + b + bn} \\ \end{array}} \right] [/tex] And [tex] \frac{{a + an + 2bn}}{{2a + b + bn}}[/tex] would be an even better approximation to [tex]\sqrt {n}[/tex]. Even if the starting approximation is way off, if alot of iterations are complete, the answer will still be accurate. Im just wondering, why does this method work? Is there a name for this method, or anywhere i can look to find more information? Thanks, Dan. |
| Feb24-07, 12:02 AM | #2 |
Mentor
That sure seems like a complex method.
A Newton's method root finder yields a very simple iterative method: [tex] x_{n+1} = \frac 1 2 (x_n + \frac A {x_n}) [/tex] So A is the number you are computing the root of and [itex] x_0 [/itex] is your inital guess, it doesn't have to be very good. Compute [itex] x_1 [/itex] with the formula, continue. This procedure converges quadratically. |
| Feb24-07, 12:09 AM | #3 |
Hmm that method does seem good. Im still interested in the matrix method though. Im not interested in it as a way to actually calculate square roots, but as a mathematical phenomenon. Just curious as to why it works.
Ofcouse im still always going to resort to my calculator to evaluate them :) |
| Feb24-07, 01:40 AM | #4 |
well, you are essentially taking an initial value of x, and then iterate through
[tex]x_{i+1}=\frac{x_{i}+n}{x_{i}+1}[/tex] so, let [tex]f(x)=\frac{x+n}{x+1}[/tex] the fix point of f [tex]f(x)=x[/tex] is sqrt(n) you can check derivatives and find out when this fix point is asymptotically stable. |
| Feb24-07, 02:19 AM | #5 |
| Feb24-07, 02:26 AM | #6 |
Just researched it on wikipedia, and now understand what a fixed point is.
[tex] \begin{array}{l} f(x) = \frac{{x + n}}{{x + 1}} \\ \frac{{x + n}}{{x + 1}} = x \\ x^2 + x = x + n \\ x^2 = n \\ x = \sqrt n \\ \end{array} [/tex] That pretty much exactly answers my question. Thanks very much for that |
| Feb24-07, 11:31 AM | #7 |
hehe, if you want to dig deep. Do you know why this works for All n?
well, the reason, is, the absolute value of f'(x) at the fixed point is less than 1 for all n except n=0. there is a theorem that says (from my difference equation book) if x* is a fix point for f and f is continuously differentiable at x* then (1) if |f'(x*)| < 1, then x* is asymptotically stable. (2) if |f'(x*)| > 1, then x* is unstable. so that in your case, x* is asymptotically stable. what if |f'(x*)|=0? then you need to do a lot more tests... if you want to know more. go to the library and pick up a difference equation book.... |
| Feb24-07, 02:56 PM | #8 |
The analysis is a lot easier in the case of multiplying by a matrix.
![]() The eigenvalues of the matrix [tex] \left[ {\begin{array}{*{20}c} 1 & n \\ 1 & 1 \\ \end{array}} \right] [/tex] are [tex]1 \pm \frac{\sqrt{n}}{2}[/tex] If you take (almost) any vector and repeatedly multiply by the matrix A, the result will approach the eigenspace associated to the largest eigenvalue in magnitude. Here, that's [itex]1 + \sqrt{n} / 2[/itex]. Given the rest of the discussion, I expect that the eigenspace associated to the eigenvalue [itex]1 + \sqrt{n} / 2[/itex] is the set of all: [tex] a \left[ {\begin{array}{c} \sqrt{n} \\ 1 \end{array}} \right] [/tex] In fact, I would go so far as to expect A to factor as: [tex] \left[ {\begin{array}{cc} 1 & n \\ 1 & 1 \\ \end{array}} \right] = \left[ {\begin{array}{cc} \sqrt{n} & -\sqrt{n} \\ 1 & 1 \\ \end{array}} \right] \left[ {\begin{array}{cc} 1 + \frac{\sqrt{n}}{2} & 0 \\ 0 & 1 - \frac{\sqrt{n}}{2} \\ \end{array}} \right] \left[ {\begin{array}{cc} \sqrt{n} & -\sqrt{n} \\ 1 & 1 \\ \end{array}} \right]^{-1} [/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculating Square Roots - Matrix Algorithm
| Derivatives of square roots | Calculus | 11 | ||
| square roots and fractions | Precalculus Mathematics Homework | 7 | ||
| Square roots | Introductory Physics Homework | 7 | ||
| square roots | Brain Teasers | 12 | ||
| Square Roots | General Math | 6 | ||
