How Is the Potential Calculated at the Center of a Charged Copper Sphere?
The discussion revolves around calculating the electric potential at the center of a charged copper sphere, given the electric field at its surface. The problem involves concepts from electrostatics, specifically relating to electric fields and potentials.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between electric field and potential, questioning how to derive the charge from the given electric field. There are attempts to clarify the distinction between electric field and charge, and discussions about the correct equations to use for potential and charge calculations.
Participants are actively engaging with the problem, with some providing guidance on how to calculate the charge based on the electric field. There is a recognition of the need to check signs in calculations, particularly regarding the potential being negative, which prompts further exploration of the underlying concepts.
There is mention of the potential being defined as zero at infinity, and the implications of the electric field direction on the potential at the center of the sphere. Some participants express confusion about the signs in their calculations, indicating a need for further clarification on this aspect.
stylez03
The electric field at the surface of a charged, solid, copper sphere is 4200 N/C, directed toward the center of the sphere. The sphere has a radius of 0.190 m.
What is the potential at the center of the sphere, if we take the potential to be zero infinitely far from the sphere?
The potential is the same outside/insider right so that leaves:
[tex]V_{surfrace} = \frac {q} {4*pi*(8.85*10^{-12})*R}[/tex]
[tex]V_{surfrace} = \frac {4200*10^{-19}} {4*pi*(8.85*10^{-12})*0.190}[/tex]
Note that electric field is not the same as charge.
So this should involved [tex]\vec {E}[/tex] somehow right?
[tex]E = \frac {1} {4*pi*E_{0}} * \frac {q} {R^{2}}[/tex]
Yes, you need to use this to determine the charge on the surface of the sphere.
So the relation with Electric Field to potential would be:
[tex]V = q*E[/tex] ?
No. Take your previous equation and use to to calculate q
Ohhh I see
[tex]Q = \frac {R^{2}E} {K}[/tex]
hm, I tried the following equation and it said it was wrong?
[tex]Q = \frac {(0.190)^{2} * 4200} {\frac {1} {4*pi*E_{0}}}[/tex]
[tex]Q = 1.68*10^{-8}[/tex]
The question didn't ask you for the charge, it asked you for the potential inside the sphere...
So after finding charge q, I need to substitute it back into
[tex]V = \frac {Kq} {r}[/tex]
Yes...
Hootenanny said:
Yes...
I had one final question on this problem. I just got the answer, but when I did the calculation it came out to be positive value but the online program said to check my signs, meaning it should be negative. I'm not sure what the intuition is behind the solution being negative, would you know or could you explain that quickly. Thank you again for your time and patients. Starting to understand the difference for charge/potential.
The clue is in the question
The electric field is define such that it is directed away from positive charge and towards negative charge. Or from from points of higher potential to lower potential, therefore, if the electric field is directed towards the centre of the sphere, then the centre must be at a lower potential than the outside of the sphere. Since zero potential (i.e. V=0) is taken to be at [itex]r=\infty[/itex], then the potential at the centre must be negative. Does that make sense? (Apologies if it doesn't but I'm running out of coffee )
Its been a pleasure :smile:
Once you got your head round potential vs. field vs. potential energy you'll sail the rest of electrostatics.
  • · Replies 21 ·
  • · Replies 43 ·
