Help calculate pipe outlet pressure
  • Thread starter Thread starter BIGEYE
    Pipe Pressure
The discussion focuses on calculating the outlet pressure of a conical pipe system with an inlet diameter of 80mm and an outlet diameter of 140mm, where the inlet pressure is 0.5 bar and the fluid density is 1000 kg/m³. The calculations provided by the user initially resulted in an outlet pressure of 0.58 bar, which was incorrect due to a misunderstanding of head levels. The correct approach involves setting the outlet as the datum level and adjusting the head calculations accordingly, recognizing that a higher outlet results in a lower pressure.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation
  • Knowledge of cross-sectional area calculations for pipes
  • Familiarity with pressure and head relationships in fluid systems
  • Basic skills in algebra for solving equations
  • Study Bernoulli's equation in detail, focusing on its application to fluid flow in pipes
  • Learn how to calculate cross-sectional areas for different pipe geometries
  • Research the concept of datum levels in fluid mechanics
  • Explore the relationship between head and pressure in fluid systems, particularly for water
Engineers, fluid mechanics students, and anyone involved in hydraulic system design or analysis will benefit from this discussion.
BIGEYE
Where am I going wrong? Appreciate if someone can take a look at this and show me where I am going wrong.
A conical pipe with inlet diameter 80mm and inlet pressure 0.5 bar, is inclined so that the outlet is 2m higher than the inlet. The outlet diameter is 140mm, the fluid density is 1000 kg/m3, and the mass flow rate is 40 kg/s.
Calculate:
a) The inlet and outlet velocities
b) The outlet pressure
My workings are giving the outlet pressure higher than the inlet pressure,which must be wrong due to the head and increased diameter. Here is how I arrived at my answers:
First calculate the inlet velocity V1
Calculate CSA of inlet (A1)
A1 = (PI × 0.08^2)/4
= 5.02 × 10^-3 m2
Calculate CSA of outlet (A2)
A2 = (PI × 0.15^2)/4
= 0.0154 m2
Inlet Velocity V1
V1 = Q/(A1 × ρ)
V1 = 40/(0.00502 × 1000)
= 7.968 m/s
Outlet Velocity V2
V2 = Q/(A2 × ρ)
V2 = 40/(0.015 × 1000)
= 2.67 m/s
Outlet Pressure Calc
Inlet Pressure P1 = 0.5 bar = 50000 pa
Inlet head h1 = 0 m
Outlet head h2 = 2m
Gravity = 9.81
gh1+ 1/2 V1^2+ (P1/ρ) = gh2+ 1/2 V2^2+ (P2/ρ)
= (9.81 × 0) + 1/2 x 7.968^2 + (50000/1000) = (9.81 × 2) + 1/2 x 2.67^2 + (P2/1000)
81.74 = 23.18 + (P2/1000)
P2 = 1000(81.74-23.18)
P2 = 58560 pa
P2 = 0.58 bar
Attached is a diagram of the pipe.
Ah, I see.
You have the wrong sign on the outlet head level. It is higher and therefore has a lower head (with positive being in the downwards direction on your drawing).
What you always want to do is start from the outlet where you know the fluid's pressure (generally atmospheric) and set that as the datum level then the h part for the inlet will be a positive value if lower and negative if higher.
PS i use the terms head and pressure to mean the same thing with water flow. The other thing to do to make calculations easier if dealing with water is to ignore the density (and gravity in the static part of the bernoulli equation) unless you really need to and just work in meters of head where 10m of water is approximately equal to 1 bar
  • · Replies 16 ·
  • · Replies 26 ·
