Power Density of Solar Cell Question
The power density of solar cells in direct sunlight is approximately 15 mW/cm². To power a sensor node that consumes an average of 10 mW, a solar cell array of at least 28,800 cm² is required, assuming direct sunlight is available for 12 hours daily. This calculation accounts for the total energy consumption over a 24-hour period, factoring in the need for excess power storage for nighttime use. Additionally, to ensure continuous operation, the area may need to be doubled to accommodate energy losses during periods of no sunlight.
  • Understanding of solar cell power density
  • Basic knowledge of energy consumption calculations
  • Familiarity with sensor node power requirements
  • Concept of energy storage for nighttime use
  • Research solar cell efficiency and power density variations
  • Learn about energy storage solutions for solar applications
  • Explore the design considerations for solar cell arrays
  • Investigate the impact of environmental factors on solar energy generation
Engineers, renewable energy enthusiasts, and students studying solar technology or energy management will benefit from this discussion.
T-Man78
I have this homework question I can't quite figure out. Any help is greatly appreciated.
In direct sunlight, solar cells have a power density of approximately 15 mW/cm2. Suppose a sensor node consumes on average 10mW of power. How large of a solar cell array is needed to meet this requirement assuming direct sunlight is available for 12 hours each day? (Assume all excess power generated during the day can be stored and used during the night).
My thinking is this: maybe I'm right maybe I'm wrong
15mW/cm2 x Y cm2 = 10mW * 43200s
Y = 28,800 cm2
Shooting from the hip, as I'm not sure what a sensor node is, but I figure its overhead, as it helps to keep the cells aligned. So in designing an array, you need to keep track of losses. In sun then you need enuf area to meets its demands=this is easy, you need 10/15 cm^2. Each cm^2 delivers 15 mW, and you need only 10. Now if it runs all the time, and it only gets lit 1/2 the time, then you have payback during the night. It is still consuming but not generating, in which case you need to figure in twice the area.
  • · Replies 30 ·
  • · Replies 25 ·
