Complex Analysis: Evaluating an Integral for Branch Cuts in the Limit r → ∞
  • Thread starter Thread starter kakarukeys
    Integral
The discussion revolves around evaluating a complex integral in the limit as \( r \rightarrow \infty \), specifically focusing on branch cuts in the context of complex analysis. The integral involves a function with branch cuts on the imaginary axis, and participants are exploring various contour integration techniques to handle the singularities present in the problem.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss different contour integration strategies, including pushing contours around branch cuts and considering semicircular paths. There are attempts to define contours that avoid singularities while ensuring convergence of integrals. Questions arise regarding the behavior of the integrand along these contours and the implications of the imaginary part of the exponential function.
The discussion is active, with participants sharing various contour ideas and questioning the validity of their approaches. Some guidance has been offered regarding the behavior of the integrand and the need for exponential decay in certain regions of the contour. Multiple interpretations of the contour paths are being explored without reaching a consensus.
Participants are working within the constraints of the problem as presented in Peskin & Schroeder's "Introduction to Quantum Field Theory," and there are references to specific pages where the problem can be found. The discussion reflects a collaborative effort to clarify assumptions and refine approaches to the integral evaluation.
kakarukeys
find in the limit [tex]r\rightarrow\infty[/tex]
[tex]\frac{-i}{2(2\pi)^2r}\int^\infty_{-\infty}\frac{p\exp(ipr)dp}{\sqrt{p^2+m^2}}[/tex]
the solution (or rather a hint) given by the book:
"The integrand, considered as a complex function of p, has brunch cuts on the imaginary axis starting at [tex]\pm im[/tex].
http://www.stochasticsoccer.com/contour.gif
To evaluate the integral we push the contour up to wrap around the upper branch cut. Defining [tex]\rho = - ip[/tex], we obtain
[tex]\frac{1}{4(\pi)^2r}\int^\infty_{m}\frac{\rho\exp(-\rho r)d\rho}{\sqrt{\rho^2-m^2}}[/tex]
in the limit, tends to
[tex]\exp(-mr)[/tex]
I can't find any theorem in complex analysis that permits a "push" of the contour shown in the figure, so I try the contour shown below:
http://www.stochasticsoccer.com/contour2.gif
but when I take limit R goes to infinity, the maximum modulus integral bound around the semicircle doesn't go to zero. so I'm stuck. Expert pls help me.
BTW: Which book?
As for contours away from the real and imaginary axes, I would consider integrating with \rho = i*m - \delta +Re^{i\theta }
from \theta = \theta_0 to \pi/2 - \theta_0 and then \pi/2 + \theta_0 to \pi - \theta (or opposite orientation ?)
and have \delta and \theta_0 vanish appropriately as R-> \infty.
The idea would be to have the imaginary part in the exponential be positive so that you get exponential decay in the semi circular part of the contour for large R. The rest maybe would converge to the desired integrals, but I did not check this all the way. However, a change in sign in the imaginary part of the exp function in the integrand occurs as arg \rho goes from \pi/2-\theta_0 \pi/2+\theta_0 which I suppose makes the contributions add (and not cancel) along the imaginary axis in the limit R-> \infinity.
(I didn't give equations of contours exactly like the pictures - well I'm only trying to help...)
The book is Peskin & Schroeder, Introduction to Quantum Field Theory
the problem is somewhere in p.g. 1~30
Let me spend some time figure out what you are saying.
I am thinking of contour that's almost a semi-circle, except for a thin wedge at a small angle that goes slightly below i*m and the larger arc not quite \pi radians across and not quite lying on the x-axis.
On second thought you may get away with
\theta = 0 to \pi/2 - \theta_0 and then \pi/2 + \theta_0 to \pi
(Maybe part of contour can exactly on x-axis - Am I overzealous in trying to keep the argument of the exponent in having a strictly **positivie imaginary part**?).
Just making the U shape in your picture more like a skinny V shape with vertex slightly under the singularity and making the contour not quite lying on the x-axis.
I bet you mean this:
http://www.stochasticsoccer.com/contour3.gif
along the big "semicircle", let [tex]p = R\exp(i\theta)[/tex], integrate from [tex]\theta_0[/tex] to [tex]\pi/2-\theta_0[/tex] then [tex]\pi/2+\theta_0[/tex] to [tex]\pi - \theta_0[/tex]
Let [tex]\theta_0\rightarrow 0, R\rightarrow\infty[/tex] later.
along the small "circle", let [tex]p = I am + z[/tex] where [tex]z = \delta\exp(i\omega)[/tex], integrate from [tex]\pi/2 - \theta_1[/tex] to [tex]\pi/2 + \theta_1 - 2\pi[/tex].
Let [tex]\delta\rightarrow 0, \theta_1\rightarrow 0[/tex] later?
:wink: Is that what you mean? I check (loosely) that the maximum modulus bound tends to zero
Nice picture. I was thinking of a V with a small angle instead of a "small circle" going under the singularity, but I think you got the picture - literally.
Good luck.
