Thread Closed
Rod travelling at near c
Share Thread
Feb27-07, 03:54 AM   #1
Suppose person A and rod R are moving with a relative velocity nearing 'c'
If the rod is angled with respect to A's direction of motion,how would the rod look like to him?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb27-07, 04:03 AM   #2
Quote by anantchowdhary View Post
Draw a box, perpendicular to the direction of motion, around the rod. Then the depth of the box is contracted and the width and height of the box stays the same. From there you can calculate the effective contracted length.
Feb27-07, 05:09 AM   #3
ok thnx a lot.Just wanted to be sure
Feb27-07, 11:18 AM   #4
Mentor
[edited to change the original [itex]\theta[/itex] to [itex]\theta_0[/itex], to make clear that this angle is the "proper" angle of the rod with respect to the x-axis, that is, the angle measured in the rod's rest frame.]
For simplicity, let the velocity be in the x-direction and the rod be oriented at an angle [itex]\theta_0[/itex] with respect to the x-axis in the rod's rest frame. The proper length of the rod has components
[tex]L_{0x} = L_0 \cos \theta_0[/itex]
[tex]L_{0y} = L_0 \sin \theta_0[/itex]
The x-component undergoes length-contraction but the y-component does not:
[tex]L_x = L_{0x} \sqrt { 1 - \frac{v^2}{c^2} }[/tex]
[tex]L_y = L_{0y}[/tex]
The length of the moving rod is
[tex]L = \sqrt{L_x^2 + L_y^2}[/tex]
Putting all these together I get
[tex]L = L_0 \sqrt{1 - \frac{v^2}{c^2} \cos^2 \theta_0}[/tex]
For [itex]\theta_0 = 0[/itex] (velocity parallel to the rod) this gives the usual length-contraction formula. For [itex]\theta_0 = 90^\circ[/itex] (velocity perpendicular to the rod) there is no contraction, as expected.
Feb27-07, 11:38 AM   #5
Well...shudnt ust the radius of the rod change?This is as the rod is moving parallel to the x axis even though it is angled.Its motion is not at an angle
And i just posted one of the equations :[tex] L_0_y = \frac {L_y} { \sqrt {1 - \frac {{0}^2} {c^2}}} [/tex] in another thread and a member said it was incorrect.I said that if the relative velocity in the direction of the y axis is zero, then [tex]L_0_y=L_y[/tex]
Was i wrong?
Feb27-07, 01:21 PM   #6
Mentor
The motion of the rod is along the x-axis, thus only length components parallel to the x-axis will be "contracted". (Why do you think this only affects the radius of the rod??)
Nothing wrong with this (which is exactly as jtbell explained).
Feb27-07, 09:22 PM   #7
thanks.No i just meant to say if the rod was a cylinder its radius as viewed would change.
So wouldnt the rod just appear to get thinner and thinner?
Also the rod isnt a vector!Its velocity is a vector which is just parallel to the x axis.
Was my question misunderstood?
Feb27-07, 11:51 PM   #8
Mentor
Consider a rectangular object whose sides are parallel to the x- and y- axes. The object moves along the x-direction. The width along the x-direction contracts, but the width along the y-direction does not, right?
Now imagine that your rod is embedded inside this rectangular object, extending from one corner to the diagonally opposite corner. The ends of the rod stay at the corners of the object as the object contracts as described above.
Feb28-07, 12:42 AM   #9
thats wat i had thought.But someone suggested that the angle would change?I dont think that would happen.Is it so?
Feb28-07, 01:10 AM   #10
Mentor
I've edited my post above to make clear that the angle in my equations is the angle that the rod makes with the x-axis, in the rod's rest frame. That is, it's the "original" angle.
In a frame in which the rod is moving, the angle is different, except if the angle is either 0 or 90 degrees to begin with. That is, if the rod is parallel to the relative velocity, in its own rest frame, it is parallel in the other frame. Likewise if the rod is perpendicular to the relative velocity.
To see this, start with the angle of the rod in the "moving" frame:
[tex]\cos \theta = \frac{L_x}{L}[/tex]
Using the other equations in my previous post, you can find
[tex]\cos \theta =\frac {\cos \theta_0 \sqrt {1 - \frac {v^2}{c^2}}} {\sqrt {1 - \frac {v^2}{c^2} \cos^2 \theta_0}}[/tex]
See what happens when [itex]\theta_0 = 0[/itex] and when [itex]\theta_0 = 90^\circ[/itex]?
Feb28-07, 01:56 AM   #11
Why would we need to take the component of the rod?Shouldnt we be just taking the component of the relative velocity [tex]\vec v[/tex] ?And in this case as the direction of the vector is parallel to the x axis,even though the length of the rod makes an agle with the axis ,the rod should just go thinner!
Feb28-07, 07:50 AM   #12
Mentor
The only dimension that "contracts" is the component parallel to the relative velocity, which is the x-component, in this example.
All dimensions of the rod parallel to the x-axis will be contracted. In particular, the x-component of the rod's length will be contracted. (Sure, it will get thinner too, so what?)
Feb28-07, 09:10 AM   #13
so the angle wont change isnt it?
Feb28-07, 09:18 AM   #14
Mentor
As jtbell explained in detail, the angle the stick makes with the x-axis will be different when measured from a moving frame. How could it not be? The angle the stick makes is given by [itex]\tan\theta = L_x/L_y[/itex]--since [itex]L_x[/itex] changes while [itex]L_y[/itex] does not, [itex]\theta[/itex] must change.
Feb28-07, 11:46 AM   #15
hmmm...so this is because space is contracting....
Feb28-07, 03:06 PM   #16
Mentor
Was i wrong?
You were not referring to the dimensions of the rod in that other thread, but to a y component of motion. That is why I said that was wrong.
Feb28-07, 09:23 PM   #17
umm.even if i was referring to the component of velocity,i meant to say as there is no velocity in the y direction,ther would be no length contraction in the y direction.Isnt that so?I was just seeing that as a reason to explain why there is no length contraction in the case given in the y direction
Thread Closed
Similar discussions for: Rod travelling at near c
Thread Forum Replies
Travelling... I need a map General Astronomy 7
Car travelling around arc of circle Introductory Physics Homework 3
car travelling Introductory Physics Homework 1
Travelling to the moon. Astrophysics 9
Travelling Problem Set Theory, Logic, Probability, Statistics 1
