Design idea about Microstrip bandpass filter
This discussion focuses on designing a 2.4GHz microstrip bandpass filter, comparing methods such as hairpin filters, interdigital filters, and combline filters. The most successful method identified is the interdigital filter, achieving an average insertion loss of 0.5 dB. Participants noted that microstrip filters require precise etching for optimal performance, as inaccuracies can significantly increase insertion loss. Additionally, hairpin filters are challenging to design without CAD tools, while coupled-line filters are the easiest to implement.
  • Understanding of microstrip filter design principles
  • Familiarity with CAD tools for filter design
  • Knowledge of insertion loss and its impact on filter performance
  • Experience with PCB fabrication techniques
  • Research "Interdigital filter design techniques" for optimized performance
  • Explore "Microstrip filter etching methods" for precise fabrication
  • Learn about "Coupled-line filter design" for simpler implementations
  • Investigate "CAD software for RF filter design" to enhance design accuracy
Engineers and designers involved in RF circuit design, particularly those focused on microwave filter development and PCB fabrication techniques.
vincenthou
Hi everyone, I am recently starting a new project on designing a 2.4GHz microstrip bandpass filter, but there are so many ways doing this, which method is better for microstrip? hairpin-filter? interdigital filter? or combline filter?
Is there any website or material anyone can recommend which relate to this topic? Thank you!:smile: :smile:
I built all of those filters. I found that some sort of tuning is required to optimize its response. Therefore the interdigital filters I did were most successful. I obtained an average insertion loss of 0.5 dB.
Microstip filters are very nice too but you can't tune them. The problem with those is the traces have to be etched very precisely and symmetrically for a good response. If you are off a bit, then you are increasing the insertion loss by a lot. If something is uneven, a pole can be outside your bandwidth. So unless you can print out the traces and transfer them on a PCB, then this route would be fun to explore. Hairpin types are difficult to design without a CAD. The easiest are coupled-lines, in most cases half or a quarter wavelength is all it takes.
http://images.google.com/imgres?img...firefox-a&rls=org.mozilla:en-US:official&sa=N
http://www.lpkf.com/applications/rapid-pcb-prototyping/design-articles/design-article2.htm
There is a third type of cheap filters to construct using copper pipe caps. These work very well too with a very high Q if you polish the inside.
http://www.czd.org.uk/astro/radioastro/filter/index.html
Hope that helps.
10K
10K
