Find i(t) for t>0 if i(0) = 2A?
  • Thread starter Thread starter 3DTiger
The discussion focuses on finding the current i(t) for t > 0 given the initial condition i(0) = 2A. The instructor advises removing the inductor and replacing it with a test source, specifically a 1A current test source. The voltage across this test source, Vtest, is calculated to be 30V, leading to a Thevenin resistance of 30 ohms. The participants clarify the nature of the "5i" component, identifying it as a current controlled current source (CCCS) that can be disregarded due to its shorted input.
  • Understanding of Thevenin's theorem
  • Familiarity with current controlled current sources (CCCS)
  • Knowledge of PSPICE for circuit simulation
  • Basic principles of circuit analysis and test sources
  • Study Thevenin's theorem applications in circuit analysis
  • Learn about current controlled current sources (CCCS) in depth
  • Practice circuit simulations using PSPICE
  • Explore techniques for analyzing circuits with test sources
Electrical engineering students, circuit designers, and anyone involved in analyzing and simulating electrical circuits.
3DTiger
The hint from the instructor says to remove the inductor and replace it with a test source. First of all I hope I have the PSPICE schemtic drawn correctly. The dependent current source is .5i. Should I use a 1A current test source. That would make i test equal to the 1 A test source. Would V test be the voltage across the 1 A test source? If so, Vtest would be equal to 30 V. Then R thevenin would be vtest/i test = 30 ohms.
What's the "5i" thing in the middle? It looks kind of like a current controlled voltage source (CCVS), but its input is shorted out?
It seems to be a current controlled current source, but as you said the input branch is shorted, so it can be totally dismissed.
  • · Replies 38 ·
9K
  • · Replies 16 ·
