Calculating Length of Wire in a Generator Coil with Given Parameters
  • Thread starter Thread starter cheechnchong
    Electric Generator
The discussion revolves around calculating the length of wire in a generator coil based on given parameters, including the number of turns, magnetic field strength, frequency, and rms emf value. The problem is situated within the context of electromagnetism and generator operation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the rms value of emf and the implications of the sine function in the equation. There is exploration of the area of the coil and its relation to the total length of wire needed. Some participants question whether to account for the number of turns in their calculations.
Participants are actively engaging with the problem, offering hints and clarifications regarding the equations involved. There is a recognition of the need to adjust calculations based on the number of turns and the nature of the coil's shape. Multiple interpretations of the setup are being explored, particularly regarding the area and length calculations.
Some participants express confusion about the relationship between the instantaneous emf and the rms value, as well as how to properly account for the geometry of the coil in their calculations. There is mention of a discrepancy between calculated and expected answers, prompting further inquiry into the assumptions made.
cheechnchong
A generator uses a coil that has 100 turns and a 0.50-T magnetic field. The frequency of this generator is 60.0 Hz, and its emf has an rms value of 120 V. Assuming that each turn of the coil is a square (an approximation), determine the length of the wire from which the coil is made.
Emf = NABwsin(wt) -- not sure if i should utilize sin(wt)?
and w = 2(pi)f
I notice that the problem includes emf as an rms value. I figure that it is sq(2). Then, I figure out the w - the value is 377.
The problem setup so far is...
sq(2)*120V = (100 turns)(A)(0.50-T)(377) sin (377*.02) ---- i figured time, t by using the frequency T = 1/f equation.
Solving for A, I get A = .069 m^2. I then solve for the radius using A = (pi)r^2 and get r = .148 m. Then, I plug the r into L = 2(pi)r to get length. My answer is L = .931 m (final answer).
Book Answer: 38 m
Now the answer I was given doesn't match with what i was given. I am guessing whether I should multiply by 100 since there are that many turns in the coil? Or just ignore the sin(wt) part? I just don't know how to fix this problem. My book does a horrible job explaining how to approach generator problems.
That equation will give you the instantaneous Emf--but you need the RMS value. Big hint: Replace sin(wt) by 1/sq(2).
Get rid of that sin(wt) term and your value for time.
It's a square, not a circle.
Of course--you want the total length of the wire.
See my comments above.
I used the equation E = NABw(1/sq(2)). I solved for w using w = 2(pi)f. Plugged all the values into the equation and got A = .009 m^2.
This is where I'm stuck...After solving for the side of the square A = s^2 using .009 m^2 (area that was figured), I came up with s = .095 m. How can I figure the L-value? I'm STUCK here!
What's the fix there doc?
What's the circumference of a square? How many squares do you have?
Doc Al, you are awesome! worked out just fine...
10K
