Solving Pressure with Gases in a Diving Bell
  • Thread starter Thread starter Antepolleo
    Gases Pressure
The discussion focuses on calculating the height of seawater that rises in a diving bell and the minimum pressure required to expel this water. The diving bell is a closed cylinder with a height of 2.10 m, initially containing air at 16.0°C, and is submerged to a depth of 86.0 m in seawater with a density of 1.025 g/cm³. The pressure at depth is determined using the formula P(z) = gpz + P_0, where g is the acceleration due to gravity, p is the water density, and P_0 is the atmospheric pressure at sea level. The volume of air at depth is calculated using the ideal gas law, leading to the conclusion that the height of water in the bell can be expressed as h = L [1 - V(z)/V_0].
  • Understanding of fluid mechanics, specifically hydrostatic pressure.
  • Familiarity with the ideal gas law and its application in varying conditions.
  • Knowledge of thermodynamics, particularly the concepts of thermal equilibrium and absolute temperature.
  • Basic mathematical skills for solving equations involving pressure, volume, and temperature.
  • Research hydrostatic pressure calculations in fluid dynamics.
  • Study the ideal gas law and its applications in real-world scenarios.
  • Explore the principles of thermal equilibrium in thermodynamics.
  • Learn about the effects of temperature on gas volume and pressure in closed systems.
This discussion is beneficial for physics students, engineers working with underwater equipment, and anyone interested in the principles of buoyancy and gas behavior under pressure.
Antepolleo
Here's the problem:
4. A diving bell in the shape of a cylinder with a height of 2.10 m is closed at the upper end and open at the lower end. The bell is lowered from air into sea water ( p = 1.025 g/cm3). The air in the bell is initially at 16.0°C. The bell is lowered to a depth (measured to the bottom of the bell) of 47.0 fathoms or 86.0 m. At this depth the water temperature is 4.0°C, and the bell is in thermal equilibrium with the water.
(a) How high does sea water rise in the bell?
(b) To what minimum pressure must the air in the bell be raised to expel the water that entered?
My question is, how are you supposed to figure this out without knowing the diameter of the bell?
Hmm.. I tried an approach where I let the number of moles of the gas be constant, but it got me nowhere.
My approach would be this...
P(z) = gpz + P_0
where P(z) is the pressure as a function of depth z below sea level,
g is acceleration of gravity, p (rho) is density of water, P_0 is pressure at sea level (i.e. one atmosphere).
You have been given p and z, and you can look up g and P_0, so you can solve for P(z).
Then if we make the assumption that none of the air in the cylinder dissolves in the water as the cylinder is lowered (number of moles is constant, as you say), we should have
P(z)V(z)/T(z) = P_0 V_0/T_0
where V(z) is the volume of air in the cylinder at depth z, T(z) is the absolute temperature at depth z, V_0 is the volume of the entire cylinder, and T_0 is the absolute temperature at sea level.
You can solve this for V(z), since you know all the other quantities.
The height to which the water rises is h = L [1-V(z)/V_0] where L is the length of the cylinder.
  • · Replies 34 ·
  • · Replies 21 ·
18K
