Parallel Plates and Electric Field
The discussion focuses on calculating the electrostatic potential energy of a system of point charges and the electric field between two parallel plates. The potential energy for charges q1 = 1 µC, q2 = 2 µC, and q3 = 3 µC at the corners of an equilateral triangle with side length s = 30 cm is determined to be approximately 0.330 J. For the parallel plates separated by d = 0.40 cm with a potential difference of 360 V, the electric field strength is calculated to be 90 kN/C. Both calculations are confirmed as correct by participants in the discussion.
  • Understanding of electrostatic potential energy calculations
  • Familiarity with Coulomb's law and the constant k (Coulomb's constant)
  • Knowledge of electric field concepts and uniform fields
  • Ability to perform unit conversions (e.g., cm to m)
  • Study the derivation of Coulomb's law and its applications in electrostatics
  • Learn about the concept of electric field strength and its calculation in various configurations
  • Explore the principles of superposition in electric fields
  • Investigate the relationship between potential difference and electric field in parallel plate capacitors
Students in physics, electrical engineers, and anyone interested in understanding electrostatics and electric fields in practical applications.
Soaring Crane
The electrostatic potential energy of a system of point charges q1 = 1 µC, q2 = 2 µC, and q3 = 3 µC at the corners of an equilateral triangle whose side s = 30 cm is
a. 1.10 J
b. 0.990 J
c. 0.631 J
d. 0.330 J
e. 0.123 J
See below.
PE = k*q*q_0/(r)
PE_total = [(k*(1*10^-6 C)*(3*10^-6 C)/(.30 m)] + [(k*(1*10^-6 C)*(2*10^-6 C)/(.30 m)] + [(k*(3*10^-6 C)*(2*10^-6 C)/(.30 m)]
= k/.30 m*[(3*10^-12 C^2) + (2*10^-12) + (6*10^-12)] = 0.3296 J ??
Two flat parallel plates are a distance d = 0.40 cm apart. The potential difference between the plates is 360 V. The electric field at a point midway between the plates is approximately
a. 90 kN/C
b. 3.6 kN/C
c. 0.9 kN/C
d. zero
e. 3.6*10^5 N/C
See below.
E = delta V/d = 360 V/0.004 m = 90,000 V/m = 90,000 N/C ?
Thanks.
Your solutions appear correct to me.
Potential energy is the sum of the energys required to add each charge in sequence (when dealing with discrete charges). You have followed this rule in your calculations adding first the 1 microC, then the 3 microC then the 2 microC (this is implicit in the way you wrote out the equations). The order is not important since E fields superpose linearly (ie they add up in the simplest way).
The second problem also seems right to me. This is a uniform field problem and the calculated value of field strength is constant thoughout the region.
  • · Replies 16 ·
  • · Replies 16 ·
