Thread Closed
Rotational Equilibrium and Rotational Dynamics
Share Thread Thread Tools
Mar1-07, 08:21 PM   #1
Question Details:
A 10 kg engine is rotating at the rate of 20 rad/sec about a point on a wire 3 meters in length with a working tensile strength of 1.8*106 N. The engine is fired and produces an acceleration of 1 rad/sec2. What's the maximum possible ω (angular velocity) (in other words: 1) whats's the fastest ω which doesn't break the wire?) 2)How long should the engine be fired to reach the maximum possible ω? 3)How far will the engine travel in meters while it's accelerating to the maximum possible ω?
2. Relevant equations
3. The attempt at a solution
I believe it's right, however this is only #1. Need help on #2 and #3.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar2-07, 09:04 AM   #2
Recognitions:
Homework Helper Homework Help
2 can be solved with the equation
[tex]w_f = w_i + \alpha t[/tex]
since the angular acceleration is sustained as long as the engine is firing. The intial angular speed is 20 and the final is 245 rad/s. Once you solved for the time use it in the other equation that will give the angle in radians that it turned through during the burn. Using the radius you can then calculate the total distance covered during this time.
Thread Closed
Thread Tools
Similar Threads for: Rotational Equilibrium and Rotational Dynamics
Thread Forum Replies
Rotational Equilibrium and Rotational Dynamics problem Introductory Physics Homework 1
Rotational Equilibrium and Dynamics Introductory Physics Homework 31
Rotational Equilibrium and Dynamics - :) Introductory Physics Homework 2
Rotational Equilibrium and dynamics Introductory Physics Homework 7
Rotational Equilibrium and Dynamics Introductory Physics Homework 6
