Are 0 divisors always paired in a ring?
  • Thread starter Thread starter pivoxa15
    Ring
The discussion revolves around the concept of zero divisors in ring theory, specifically questioning whether zero divisors always appear in pairs. The original poster seeks clarification on the definition and implications of zero divisors, particularly in relation to the multiplication of elements in a ring.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the definition of zero divisors, questioning whether elements that multiply to zero must be paired. They discuss specific examples and counterexamples, including properties of rings that satisfy the cancellation law.
The discussion is ongoing, with participants providing differing perspectives on the definition of zero divisors and whether zero itself should be included. Some participants suggest that the definition may vary based on context or convention, while others emphasize the need for clarity in definitions.
There are references to specific texts and definitions that exclude zero from being classified as a zero divisor, indicating a potential divergence in understanding based on different mathematical conventions. The implications of these definitions on the nature of zero divisors in rings are being examined.
pivoxa15
definition
If a and b are two nonzero elements of a ring R such that ab=0 then a and b are divisors of 0 or (0 divisors). In particular a is a left divisor of 0 and b is a right divisor of 0.
My question is if you have a0=0 then a is not a 0 divisor?
So it seems that 0 divisors will always come in pairs? So whenever you have a left 0 divisor, you automatically have a right 0 divisor.
As for your question, if a*0=0, a may or may not be a zero divisor.
Eg if a = 0, then a*0 = 0*0=0 and a is not a zero divisor.
Eg if a is a left zero divisor, than a*0=0 still.
Your second example is interesting.
I realize my question in my OP isn't precise enough. I will set up my question better.
Consider ac=0 for a is not 0 and c is arbitary. a,c part of ring R.
If R satisfies the cancellation law then
ac=0
ac=a0, since a0=0
c=0
So c is forced to be 0 and so a is not a zero divisor hence no left 0 divisors in R.
If there are no left 0 divisors in R then there cannot be right 0 divisors in R. -Correct?
In this way 0 divisors in rings must come in pairs. i.e. in any ring there must be an even number of 0 divisors?
All domains have exactly one zero divisor. :-p
There are examples of either parity: consider Z mod 4 (0 and 2) and Z mod 9. (0, 3, 6)
Yes. Just look at the definition.
of course not. try to think why.
What does this mean? Could you be more specifc? Or is it meant to be a joke, in which case I don't understand.
Are you claiming 0 is a 0 divisor? The definition clearly states that 0 divisors must not be 0. i.e. ab=0 where a,b are non zero. => a,b are 0 divisors.
Although with Z mod 4, I see that 2 is the only zero divisor. i.e 2*2=0.
However, it still is the case that whenever you have a left 0 divisor, you must also have a right 0 divisor. In this example, the left and right 0 divisors turned out to be the same.
Your definition of zero divisor above is not one I would ever use. x is a left zero divisor if xy=0 for some non-zero y. Similarly for a right zero divisor. Excluding 0 as a zero divisor seems very odd to me. I suspect the book chose it to clean up the presentation of statements (i.e. 'let x be a (left) zero divisor' instead of 'let x be a non-trivial (left) zero divisor').
If you let 0 as a 0 divisor then you run into 0/0 (as 0 is a 0 divisor) which is undefined. So you shouldn't include 0 as a 0 divisor.
Erm, no, that is nonsense. At no point do you run into 0/0 issues anymore than any other issues. Let me explain:
Just think mod 12. 4*3=0 and 4*9=0 mod 12. So you can't divide by 4 (if you could then 3=9 mod 12). This is the whole point: you can't divide by zero divisors! Zero divisors are a generalization of the fact you can't divide by 0.
I see. You can't divide by 3 nor 9 because you will get 4=0 Mod 12 in both cases.
So if you include 0 as a zero divisor than it is a trivial zero divisor. In fact 0 is always a 0 divisor in whatever ring you may have. That is why Hurkyl said "All domains have exactly one zero divisor." This zero divisor is 0.
However in here http://en.wikipedia.org/wiki/Zero_divisor they used the definition I gave in my OP which is that zero divisors must be nonzero. Are you going to edit this entry Matt?
I agree with matt -- it's likely just another convention. Like whether people let 0 be a natural number, or if 0=1 is allowed in a ring. (and I greatly prefer the 0 is a zero divisor version)
My lecturer specifically said that 0=1 in a ring R if and only if R={0}. This is because 0 in this ring can act as the multiplication identiy associated with 1.
On p58 of Intro algebra by Hungerford it states the definition I gave and with an added note "Note that 0 is not a zero divisor". So Hungerford is against the notion of 0 as a zero divisor. Maybe it's because of the trivialness of 0 being a 0 divisor.
No, it's probably because if makes it easier to state things, just like we exclude units from being primes, even though they satisfy the definition of prim (p is prime if p divides ab implies p divides a or b - units divide everything). Since 0 is always a zero divisor, and you will be specifically interested in finding non-zero zero divisors, it is better to exclude them for presentational reasons. I've never had a situation where I've seen them exclude zero before.
  • · Replies 55 ·
  • · Replies 24 ·
