Cosets in Rings: Sets {a*R} & {a+R}
  • Thread starter Thread starter pivoxa15
    Cosets Rings
The discussion revolves around the concept of cosets in the context of rings, specifically examining the sets {a*R} and {a+R}. Participants explore whether these sets can be classified as cosets and discuss the implications of operations in rings compared to groups.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants question the nature of the sets {a*R} and {a+R}, debating whether they can be considered cosets. There is discussion on the definitions of right ideals and left ideals, and whether certain properties hold true for these sets. Some participants raise points about the closure properties of elements in rings and the implications of being a unit or a zero divisor.
The discussion is active, with various interpretations being explored regarding the properties of ideals and cosets in rings. Some participants provide clarifications and counterpoints, indicating a dynamic exchange of ideas without a clear consensus on the definitions and implications being discussed.
There are references to specific properties of elements in rings, such as the existence of a multiplicative identity and the nature of zero divisors. The discussion also touches on the limitations of certain assumptions regarding the operations in rings.
pivoxa15
Does cosets exist in rings?
i.e R = Ring, a in R
set {a*R}
or
set {a+R}
The above two sets looks very similar to cosets in groups but there are two operations in rings so potentially two different cosets both involving the same ring R and element a. If the above two sets are not cosets than what are they called?
The former is the right ideal generated by R, the latter is the right coset of a in R (and since addition is commutative, the left coset).
I is a right ideal if Ix is in x for all x in R. Clearly aR is a right ideal. Similarly Ra is a left ideal, and RaR is an ideal (that is a two sided ideal).
In this case aR is also a left ideal? Because x(aR) with x and a in R means xa is in R. (xa)R is a subset of R.
Similarly Ra is also a right ideal.
No, because (xa)R is not necessarily a subset of aR.
Good point. In fact x(Ra)=Ra, for x and a in R which is the ring.
Also, a + R is a rather boring coset, since a + R = R. a + I is more interesting, for ideals I.
No. x(Ra) is a subset of Ra. It is most definitely not equal to it in general (x=0, for instance).
Doh. Can't believe I missed this. Elements don't have cosets, sugroups/ideals, have cosets
Ra gives R. xR gives R again. so x(Ra)=xR=R=Ra. In this way x(Ra)=Ra. I agree that it is quite boring but at least it's correct? You think not Matt? R is the ring and a and x are elements in R. All elements in R are closed under multiplication.
Closure under multiplication means xR is a subset of R. To get the other inclusion, you need the existence of inverses. Thus x+R=R, or xR=R when x is a unit, but in general this isn't true. If the example x=0 isn't enough to convince yourself that xR is not always R, you need to go back to the definitions.
I should have said x must be non zero.
If x is a unit then x cannot be a zero divisor. This latter point is the important thing because if x was a zero divisor than some non zero entities in R may not be produced from xR. If x is not a zero divisor and is not a unit than xR=R if R does not contain the multiplicative identity, 1?
x+R=R will work all the time with x in R wouldn't it? Without any limitations on x?
zero or not zero, I don't see what this has to do with anything. Rx is still an ideal
No, clearly this is false. (Incidentally, if R doesn't have a 1 then it can't have units). If you just remembered that the integers are a ring you'd have a lot more insight into the general situation; what is 2Z? It is ring without 1, call it R. What about the ideal 4Z inside 2Z, it is the ideal 2R.
  • · Replies 20 ·
