Thread Closed
Cauchy-Riemann conditions
Share Thread Thread Tools
Mar4-07, 02:22 PM   #1
The functions u(x,y) and v(x,y) are the real and imaginary parts, respectively, of an analytic function w(z).
Assuming that the required derivatives exist, show that
[tex]\bigtriangledown^2 u=\bigtriangledown^2 v=0[/tex]
Solutions of Laplace's equation such as u(x,y) and v(x,y) are called harmonic functions.
2. Relevant equations
Cauchy-Riemann conditions:
[tex]\frac{\delta u}{\delta x} = \frac{\delta v}{\delta y}[/tex]
[tex]\frac{\delta u}{\delta y} = -\frac{\delta v}{\delta x}[/tex]
3. The attempt at a solution
I expanded [tex]\bigtriangledown^2 u = \frac{\delta u}{\delta x}\frac{\delta u}{\delta x} + \frac{\delta u}{\delta y}\frac{\delta u}{\delta y}[/tex] and using the Cauchy-Riemann conditions I found
[tex]\bigtriangledown^2 u = \frac{\delta v}{\delta y}\frac{\delta v}{\delta y} + \frac{\delta v}{\delta x}\frac{\delta v}{\delta x}=\bigtriangledown^2 v[/tex]
What I can't figure out how to do is prove that this is equal to zero.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar4-07, 02:38 PM   #2
Recognitions:
Homework Helper Homework Help
Your eqs. for del^2 are wrong.
[tex]\nabla^2 u=\partial_x\partial_x u+\partial_y\partial_y u.[/tex]
Mar4-07, 02:49 PM   #3
Dang, you're right. Can I dot it into an element of length like this?
[tex]\bigtriangledown^2 u \bullet d\vec{r}^2 = \frac{\delta}{\delta x}\frac{\delta u}{\delta x} dx^2 + \frac{\delta}{\delta y}\frac{\delta u}{\delta y} dy^2[/tex]
Mar4-07, 03:09 PM   #4
There is a hint in the problem that says I need to construct vectors normal to the curves [tex]u(x,y)=c_i[/tex] and [tex]v(x,y)=c_j[/tex]. Wow, I'm pretty lost.
Mar4-07, 04:01 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
The Cauchy-Riemann equations are
[tex]\frac{\partial u}{\partial x}= \frac{\partial v}{\partial y}[/tex]
[tex]\frac{\partial u}{\partial y}=-\frac{\partial v}{\partial x}[/tex]
which is what you have, allowing for your peculiar use of [itex]\delta[/itex] rather than [itex]\partial[/itex]!
Now just do the obvious: differentiate both sides of the first equation with respect to x and differentiate both sides of the second equation with respect to y and compare them.
Are you sure that the hint is for this particular problem? A normal vector to u(x,y)= c is
[tex]\frac{\partial u}{\partial x}\vec{i}+ \frac{\partial u}{\partial y}\vec{j}[/tex]
and a normal vector to v(x,y)= c is
[tex]\frac{\partial v}{\partial x}\vec{i}+ \frac{\partial v}{\partial y}\vec{j}[/tex].
Using the Cauchy-Riemann equations, that second equation is
[tex]-\frac{\partial u}{\partial y}\vec{i}+ \frac{\partial u}{\partial x}\vec{j}[/tex]
which tells us the the two families of curves are orthogonal but that does not directly tell us about [itex]\nabla^2 u[/itex] and [itex]\nabla^2 v[/itex].
Mar4-07, 04:31 PM   #6
Thanks for your reply.
There is a part b) to the problem, and it is this:
b) Show that
[tex]\frac{\partial u}{\partial x}\frac{\partial u}{\partial y} + \frac{\partial v}{\partial x}\frac{\partial v}{\partial y} = 0[/tex]
I solved it easily using the Cauchy-Riemann equations, so I figured that the hint was for the first part.
Thread Closed
Thread Tools
Similar Threads for: Cauchy-Riemann conditions
Thread Forum Replies
Cauchy-Riemann conditions proof Calculus 9
Curl and Cauchy-Riemann Conditions problem Calculus & Beyond Homework 2
cauchy Riemann relations Calculus 10
Cauchy-Riemann Equations Calculus 0
Cauchy Riemann Conditions Question Calculus 1
