Thread Closed
Rotation and Linear Motion Help
Share Thread Thread Tools
Mar4-07, 11:07 PM   #1
Two masses, m1 and m2, are connected by light cables to the perimeters of two cylinders of radii, r1 and r2, respectively. The cylinders are rigidly connected to each other but are free to rotate without friction on a common axle. The moment of inertia of the pair of cylinders is I = 45 kgm^2.
r1= 0.5m
r2= 1.5m
m1= 20kg
a) Find the mass of m2 so that the system is in equilibrium
b) the mass is removed and the system released from rest. Determine the angular acceleration, the cable supporting m1, and the linear speed of m1 at the time it has descended 1m.
3. The attempt at a solution
a) T=0
r1F1 - r2F2 = 0
m2= 6.7kg.
b)T=I(alpha)
then how do i go on?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar4-07, 11:34 PM   #2
What do you visualize happening to the mass and cylinders after the balancing mass is removed?
Mar5-07, 12:13 AM   #3
the wheel rotating in the direction of the heavier mass.
okay umm so my teacher wrote that i have to connect the bodies as well. do i combine the inertias of the two masses
I = I(of m1) + I(of m2).
originally i had (0.5)(20)(9.8)=45(alpha)
but he marked it wrong saying i need to connect the bodies. I dont think i fully understand what he means.
Mar5-07, 12:48 AM   #4
w/o a pic, not sure either. I was under the impression that the cylinders were held stationary while the balancing mass was removed and then allowed to accelerate. In other words you had one mass, two cylinders and a brake which was released at t=0
Mar5-07, 12:57 AM   #5
yea so i was kinda pissed he didnt put a pic on the test too. but he said that the cylinders are instantaneously stationary when the mass is removed. The smaller cylinder he said can be considered to be inside the big one. The only reason for the two radii is for the inertia equations for the masses.
thanx for replying
Mar5-07, 01:04 AM   #6
ok, then the reason they are "connected" is thru the need to conserve momentum. I'm headed for zzzzland, suspect there will be more on this issue in the morning.
Thread Closed
Thread Tools
Similar Threads for: Rotation and Linear Motion Help
Thread Forum Replies
Linear transformation rotation Calculus & Beyond Homework 3
Linear movement --> Rotation Mechanical Engineering 3
Rotation and Linear Bonus Problem Help Introductory Physics Homework 5
Rotation and Linear Motion BonuS Help Advanced Physics Homework 0
graphing rotation & linear quantites Introductory Physics Homework 9
