Use energy conservation to determine the forces
The discussion revolves around an isolated system of two particles with masses m1 and m2, exploring the forces acting between them through energy conservation principles. The potential energy function is given as U = -k/r^2, prompting participants to analyze the implications of this form on the forces involved.
  • Participants discuss the relationship between potential energy and force, questioning the meaning of variables and the nature of the potential function. There are attempts to clarify Newtonian relativity principles and their implications on the potential energy function.
The discussion is active, with participants exploring various interpretations of the potential energy function and its relationship to force. Some guidance has been offered regarding the differentiation of potential energy to find force, but there is no explicit consensus on the correct approach or understanding of the principles involved.
There is confusion regarding the nature of the potential energy function and its implications for the forces acting between the particles. Participants are also navigating the distinction between gravitational forces and the forces derived from the given potential.
imy786
Consider an isolated system comprising two particles of masses m1 and m2, whose position vectors, in an inertial frame, are x1 and x2 and whose velocity vectors are v1 and v2. The interaction of the particles may be described by an energy function
E = 1/2 m1v1^2 + 1/2 m2v2 ^2 + U(x1, x2).
(a) Suppose that U = −k/r2, where k is a positive constant. Use energy conservation to determine the forces acting between the particles.
E = 1/2 m1v1^2 + 1/2 m2v2 ^2 + U(x1, x2). (1)
U = −k/r2, (2)
substituting U = −k/r2 into (1) gives
E = 1/2 m1v1^2 + 1/2 m2v2 ^2 −k/r2
then don't know what to do to determine the forces ,
i would think that gravtional forces are acting between the particles.
What does r2 mean? r usually denotes distance from x1 to x2. So r2=r^2 or just r? In either case, the force is related to the derivative of the potential energy function U with respect to distance. Why is this post titled 'relativity'?
r2 means rsquared which should be r^2
relativity, momentum forces...
well the question was longer , and other parts involved relativty, if u want me to post the rest of the question let me know.
If the potential is k/r^2 then it's not gravity. And you're using nonrelativistic expressions for kinetic energy. Maybe you'd better post the full question.
(i)Which aspect of Newtonian relativity requires
U to depend only on the separation vector x1 − x2?
(ii) Which further aspect of Newtonian relativity requires U to depend only on the magnitude r = |x1 − x2| of the separation vector?
and part (iii) is given as question (a)
Ahhhh! NEWTONIAN relativity. Did you figure out (i) and (ii)? For (iii) I'll reiterate, the force is the negative derivative of the potential. What is the direction of the force?
no couldn't do (i) and (ii).
force will act towards the particles
What ARE the principles of Newtonian relativity?
Newtonian relativity-The special principle of relativity states that physical laws should be the same in all inertial reference frames, but that they may vary across non-inertial ones
So in particular you should be able to translate and rotate positions without affecting the physics (such as forces or potentials). What does this tell you about (i) and (ii)?
U= -Gm1m2/ x1-x2
mechanics.
If you translate the system in space, x1 and x2 change but their difference remains constant, right? Is that important?
yes it is important..well is it gravtional (netwonain relatiity that is reuqired)
Is that a question? Can you answer what principle for (i)?
(i)the principle of conservation of energy
The principle is translational invariance - a special case of frame invariance. Likewise, what would rotational invariance have to do with (ii)?
rotational invariance-
a vector quantity is rotationally invariant if its value remains the same under a rotation of its input vectors. Both the dot product and the cross product are rotationally invariant, while vector addition and scalar multiplication, in general, are not.
Basically, yes. x1-x2 is not rotationally invariant but |x1-x2| is. Now, what about your force. The latest version of the potential you sent looks more like -k/r than -k/r^2. Which is it and which force law does that lead to?
U = −k/r^2 this is the potenetial that is given in the question.
Newtons force law of gravition:
F= Gm1m2/ r^2
Fine. But if the potential is -k/r^2 then what is the force? (Don't repeat 'gravitation').
gravtional potentional
Not a sentence.
i think-
the force between the objects will be gravitonal potential.
Potential is not a force. It's a potential. Gravitational potential has the form -k/r. Your potential has the form -k/r^2, you say. Hence your potential is different and is not gravity. QED. What would the force law coming from your potential be?
well FORCE= mass* accelration,
acceleration being gravtional
what doee QED mean?.
F= KM1M2/ |x1 − x2|
QED just means 'thus it is proved'. You are giving me random answers for what the force is. You said you were given that the potential is -k/r^2. Now forget everything else except that. There is a general relationship between potential and force. What is it?
FOrce= qd
where q is the potential and d is the distance
f = m g,
U = m g y
Fx = dU / dx,
Fy = dU / dy
w = m g,
E = K + U
Most of these are either wrong or not applicable to the problem.
F=-dU/dr is the one you want.
- dU/ dx= F (x)
U (x) = - integral between x0 to x : F (x) dx + U (xo)
  • · Replies 18 ·
