Calculating Automobile Crankshaft Torque for Beginners
  • Thread starter Thread starter NanoTech
    Torque
The discussion focuses on calculating the torque delivered by an automobile crankshaft using the formula Torque (N·m) = Power (W) ÷ Angular velocity (rad/s). The power is specified as 100 hp, equivalent to 74.6 kW, and the angular velocity is given as 1800 revolutions per minute, which converts to 188.5 rad/s. By applying these values, the calculated torque is 396.2 N·m. This method provides a clear and straightforward approach for beginners to understand torque calculations in automotive engineering.
  • Understanding of power measurement in kilowatts (kW)
  • Knowledge of angular velocity in radians per second (rad/s)
  • Familiarity with the concept of torque in Newton meters (N·m)
  • Basic mathematical skills for unit conversion and formula application
  • Research the conversion of horsepower to kilowatts for automotive applications
  • Learn about angular velocity and its significance in rotational mechanics
  • Explore other torque calculation methods in automotive engineering
  • Investigate the impact of torque on vehicle performance and efficiency
This discussion is beneficial for automotive engineers, mechanics, students in mechanical engineering, and anyone interested in understanding the principles of torque in vehicle dynamics.
NanoTech
An automobile crankshaft transfers energy from the engine to the axle at the rate of 100hp(=74.6kW) when rotating at a speed of 1800 rev./min...What Torque (N~meters) does the crankshaft deliver?
Do I have to convert or is there a formula for this? Thanks! ~Dave
You will want to use: torque = power/angular velocity.
I would first convert your power to units of Newton meters per sec, and your angular velocity to radians per second, then simply plug the numbers into the equation above.
Hi Dave,
To calculate the torque delivered by the crankshaft, you will need to use the formula: Torque (N·m) = Power (W) ÷ Angular velocity (rad/s). In this case, the power is given as 100hp (=74.6kW) and the angular velocity is 1800 rev./min, which can be converted to 188.5 rad/s. Plugging these values into the formula, we get:
Torque (N·m) = 74.6kW ÷ 188.5 rad/s = 396.2 N·m
So, the crankshaft delivers a torque of 396.2 N·m.
I hope this helps! Let me know if you have any other questions.
