Sum of two planewaves using momentum operator
The discussion centers on using the momentum operator to derive an expression for the sum of two planewaves moving in opposite directions, both possessing the same kinetic energy. The momentum operator is defined as (h_bar/i)(d/dx), and the planewaves are represented as exp(kx-wt) and exp(kx+wt). The combination of these planewaves simplifies to 2cos(kx) exp(-iwt), and applying the momentum operator twice reveals that the momentum squared, p², equals (hk)², leading to p being either +hk or -hk. This results in a standing wave that indicates a particle's potential momentum measurement outcomes.
  • Understanding of quantum mechanics principles, specifically wave functions.
  • Familiarity with the momentum operator in quantum physics.
  • Knowledge of planewaves and their mathematical representations.
  • Basic grasp of the Schrödinger equation and its solutions.
  • Study the application of the momentum operator in quantum mechanics.
  • Explore the derivation of standing waves from traveling waves.
  • Learn about the implications of momentum measurements in quantum systems.
  • Investigate the relationship between kinetic energy and wavefunctions in quantum mechanics.
Students of quantum physics, physicists exploring wave-particle duality, and anyone interested in the mathematical foundations of quantum mechanics.
DevoBoy
Hi,
I'm baffled by a problem in a quantum physics course I'm taking.
Problem: "Use the momentum operator to find an expression for the sum of two planewaves moving in opposite directions. Both planewaves have the same kinetic energy."
It's in one dimension only.
I know the momentum operator is (h_bar/i)(d/dx), and one planewave is exp(kx-wt). The other is exp(kx+wt) ??
My main problem is that I don't know quite where to start. :smile: How should I use the momentum operator? The answer should be on the same form as a solution to the Scrodinger equation.. :rolleyes:
Try writing the expression expi(kx-wt) + exp-i(kx+wt). The idea is that the wavenumber changes sign, not the frequency. This simplifies to 2coskx exp-iwt. Now apply the momentum operator twice. You'll see that p^2=(hk)^2. This means that p=+/-hk.
This is a standing wave, which describes a particle moving in either +x or -x. Supposedly, a measurement of the momentum will produce either +hk or -hk.
