Conductors and co-axial cables?
  • Thread starter Thread starter Swapnil
    Cables Conductors
The discussion revolves around the electric field generated by a long conducting hollow cylinder with a surface charge density, which is placed inside another hollow, uncharged cylinder. Participants are exploring the implications of Gauss' law in this context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are examining the application of Gauss' law to determine the electric field outside the outer cylinder and questioning the assumptions about charge distribution and neutrality of the outer cylinder.
There is an ongoing exploration of the implications of charge on the inner cylinder and the resulting induced charges on the outer cylinder. Some participants are providing guidance on the application of Gaussian surfaces and the conditions for static situations, while others are questioning the nature of the outer cylinder.
Participants note that the outer cylinder is not a shell and discuss the implications of this on the charge distribution and electric field. The problem specifies only the charge on the inner cylinder, leading to discussions about induced charges and overall neutrality.
Swapnil
Conductors and co-axial cables!??
Say you have a long conducting hollow cylinder with some surface charge density [itex]\rho[/itex] which is inside another hollow (uncharged) cylinder. What would the electric field be outside the outer cylinder?
I am guessing that the e-field outside the outer cylinder should be zero because the inner cylinder would produce induced charges on the surface of the outer cylinder equal but opposite in magnitude and therefore the total charge enclosed in both of the cylinders would be zero.
Is this correct?
What does Gauss' law (in integral form), applied outside the outer cylinder, tell you? Can you spot the mistake in your reasoning?
If we choose a cylindrical gaussian surface [itex]S[/itex] outside the outer cylinder then
[tex]\oint_{S} \vec{E}\cdot d\vec{S} = Q_\text{enc}[/tex]
which is equal to zero since the total charge enclosed inside the surface is 0 (Q on the inner cylinder and -Q on the outer cylinder).
Your problem specifies only charge on the inner cylinder so Q enclosed is nonzero.
If the outer cylinder is conducting, put the gaussian surface inside the outer cylinder.
But wouldn't there be an induced charge -Q on the outer cylinder due to the inner cylinder?
But the outer cylinder/conductor is not a shell -- it doesn't have any thickness.
That's what a gaussian surface inside the outer conductor (is it a conductor) would tell you. That there is surface charge inside it.
That's an interesting problem in metaphysics. :smile:
lol
Remember what must be true for the outer conductor in a statics situation. Hint: think about the E field.
Yes, but since the outer conductor must remain overall neutral there will be an opposite charge on its outer surface.
Oh I see. So the net charge outside would then be Q (+Q on the inner conductor, -Q on the inner suface of the outer conductor, and +Q on the outer suface of the outer conductor).
Exactly as you say.
9K
