Finding emprical formula of compound CHON
  • Thread starter Thread starter jacker2011
    Formula
The empirical formula of the compound containing carbon (C), hydrogen (H), nitrogen (N), and oxygen (O) can be determined through combustion analysis. The combustion of 0.157g of the compound yields 0.213g of CO2 and 0.0310g of H2O, while 0.103g of the compound produces 0.0230g of NH3. By calculating the moles of CO2, H2O, and NH3, and converting these to grams, one can derive the masses of C, H, and N. The remaining mass will indicate the amount of O, allowing for the formulation of the empirical formula in the format C(moles C) H(moles H) N(moles N) O(moles O).
  • Understanding of stoichiometry and mole calculations
  • Familiarity with combustion analysis techniques
  • Knowledge of empirical formula determination
  • Basic chemistry concepts involving elements and compounds
  • Learn how to perform combustion analysis for empirical formula determination
  • Study mole-to-mass conversions in chemical reactions
  • Explore the calculation of percent composition from empirical formulas
  • Investigate the role of oxygen in combustion reactions
Chemistry students, educators, and professionals involved in analytical chemistry or chemical education will benefit from this discussion.
jacker2011
a compound contains only carbon, hydrogen, nitrogen and oxygen. Combustion of 0.157g of the compound produce 0.213g of CO2 and 0.0310g of H2O. In another experiment, it is found that 0.103g of compound produces 0.0230g of NH3. What is emprical formula of the compound. Hint: Combustion involves O2. Assume all the carbon ends up in the CO2 and Hydrogen ends up in water. Also assume the Nitrogen ends up in NH3 in second experiment
x+ O2= CO2 +H2O
0.213g CO2/ 44gCO2= 0.0048mole of CO2
0.0310g H2O/18G H2O= 0.00172 mole of H2O
0.023g NH3/17g NH3= 0.00135 mole NH3
To start, try to express the carbon, hydrogen and nitrogen in terms of grams. You can easily convert from moles since you have already done the hard work... remember that for the nitrogen your sample size is not the same as the CH determination. Express the nitrogen as percent of total weight of the compound and then multiply the percentage by the original wt of sample used to determine CH.
Add the mass of these three elements together. Compare the answer to the starting mass. Is it the same? What is different and why?
Once you have determined the mass of the four elements, convert to moles and express the formula in the form:
Try it from there...
9K
10K
12K
9K
14K
