Calculating Charge Density of Styrofoam and Plastic Sheet
The discussion revolves around calculating the charge density of a plastic sheet that supports a piece of Styrofoam with a known mass and charge. Participants are exploring concepts related to electric fields, forces, and Gauss's Law in the context of electrostatics.
  • Participants discuss the application of Gauss's Law to determine the electric field from the charged plastic sheet and its relationship to the forces acting on the Styrofoam. Questions arise regarding the role of mass and how to derive the necessary equations.
There is an ongoing exploration of the relationship between electric and gravitational forces, with some participants providing hints and guidance on deriving relevant equations. Multiple interpretations of how to approach the problem are being considered, but no consensus has been reached.
Participants express uncertainty about the implications of the infinite area of the charge sheet and how to incorporate the given net charge into their calculations. There is a recognition that the net force on the Styrofoam must be zero for it to remain suspended.
brunie
A 8.2 g piece of Styrofoam carries a net charge of -0.700 µC and floats above the center of a large horizontal sheet of plastic that has a uniform charge density on its surface. What is the charge per unit area on the plastic sheet?
Ive solved some other related questions with charge densities, but I can't figure out where to start on this one.
None of Gauss's Laws seem to have anything to do with mass and the area is underminable using basic algebra.
8.2g carrying -0.0000007 C
so the charge per unit area will be with units C / m^2
the flux should be equal to the charge divided by Eo
any help about solving this would be appreciated
brunie, you can apply Gauss's Law to find the electric field created by the large horizontal sheet of plastic, and if this sheet infinite, the electric field calculated is uniform.
You also know that the piece of styrofoam is in equilibrium, so what is the net force on it. I have already talked too much. :)
i don't understand how the electric field can be calculated if the area is infinite, also where would the mass be taken into account?
There are two things to understand:
(1) The field from a uniform (and infinite) plane of charge (which will be a function of the charge density). You can use Gauss's law to derive it. Hint: Start by drawing a Gaussian box around a section of the plane of charge.
(2) What field strength is required to support the piece of styrofoam? Hint: What force must the field exert on the charge styrofoam?
im not very good at deriving the equations, most of the stuff we've been doing on gauss's law has been pretty basic
could u walk me thu a few steps
should the field strength have to balance the gravitational force?
You'll find this pretty basic as well. I'd be surprised if it wasn't in your book. Anyway, see here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elesht.html#c1"
To be suspended, the net force on the styrofoam must be zero: The upward electric force must balance the downward force of gravity.
ok so
mg = ∂ / 2 Eo
(8.2/1000)*9.8 = ∂ / 2 (8.85 x 10^-12)
then do i solve for ∂ ?
y doesn't the given net charge come into account?
can n e 1 help?
Careful. The electric field from a sheet of charge is:
[tex]E = \sigma / 2 \epsilon_0[/tex]
What force does that field exert on the styrofoam? (That's where the charge comes in.)
ok, I am just having trouble seeing the big picture
we have a electric field, a electric force and gravitational force
the net force should be zero since it is suspended
but i just don't understnad how to balance or equate these forces/fields
First things first. What force does an electric field exert on a charge? (Hint: Look up the definition of electric field.)
ok
so should the expression be F / q = ∂ / 2Eo
where F = mg ?
Now you're cooking. :wink:
great, thanks 4 ur help
  • · Replies 26 ·
17K
