Find the equation of a tangent line to y=f(x)
The problem involves finding the equation of a tangent line to the curve defined by the function y = √(2x + 1) at the point (4, 3). The original poster presents their approach using the definition of the derivative.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to apply the limit definition of the derivative to find the slope of the tangent line. Some participants question the correctness of the multiplication in the numerator during the simplification process.
Participants are actively engaging with the original poster's work, providing feedback on specific steps and suggesting corrections. There is a constructive exchange regarding the simplification process, indicating a productive direction in the discussion.
The original poster expresses uncertainty about their calculations, particularly at a critical step in the limit process. There is an emphasis on ensuring the correct application of algebraic manipulation in the context of finding the derivative.
shwanky
Find the equation of the tangent line to the curve at the given point.
[tex]y = \sqrt{2x+1} , (4, 3)[/tex]
a = 4
[tex]M =\lim_{x \to a} \frac{f(x) - f(a)}{x-a}[/tex]
or
[tex]Mpq = \lim_{h \to 0} \frac{f(a+h) - f(a)}{h}[/tex]
[tex]M =\lim_{x \to 4} \frac{f(x) - f(4)}{x-a}[/tex]
[tex]M =\lim_{x \to 4} \frac{\sqrt{2x+1} - \sqrt{2 * 4 + 1}}{x-4}[/tex]
[tex]M =\lim_{x \to 4} \frac{\sqrt{2x+1} - 3}{x-4}[/tex]
[tex]M =\lim_{x \to 4} \frac{\sqrt{2x+1} - 3}{x-4} * \frac{\sqrt{2x+1} + 3}{\sqrt{2x+1} + 3}[/tex]
[tex]M =\lim_{x \to 4} \frac{2x - 3}{x-4(\sqrt{2x+1} + 3)}[/tex]
At this point I get stuck... I'm not sure what I can do from here. did I go wrong some where?
On the last step are you sure that you multiplied correctly? :P (check the numerator again)
Do you see it?
It should be 2x-8 since [tex](\sqrt{2x+1}-3) * (\sqrt{2x+1}+3) = 2x+1 -9 = 2x-8[/tex]
From that point you can divide by (x-4) quite easily resulting in a function for which you can directly substitute x=4 since the result is not in an 'indeterminate form' of [tex]\frac{0}{0}[/tex] or [tex]\frac{\infty}{\infty}[/tex]
BAH! thanks :).
  • · Replies 105 ·
13K
  • · Replies 31 ·
