What Is the Maximum Radius for a Car to Stay on a Loop-the-Loop Track at 4m/s?
  • Thread starter Thread starter tahyus
The discussion revolves around a physics problem involving a car on a loop-the-loop track, specifically focusing on determining the maximum radius for the car to maintain contact with the track while traveling at an initial speed of 4 m/s.
  • Participants explore the conservation of energy principles, questioning how kinetic and potential energy relate at different points on the track. There are discussions about whether velocity changes due to gravitational effects and the implications of energy conservation on the maximum radius.
Some participants have offered insights into the conservation of energy, suggesting that the kinetic energy at the base of the loop equals the potential energy at the top. Others are attempting to clarify their understanding of energy transformations and the relationship between radius and height in the context of the problem.
There is a mention of an impending exam for one participant, which may influence their engagement in the discussion. Additionally, the conversation includes references to specific formulas for potential and kinetic energy, indicating a focus on mathematical relationships within the problem.
tahyus
the drawing shows a version of the loop the loop trick for a small car. if the car is given an initial velocity of 4m/s what is the largest value that the radius r r can have if the car is to remain in contact with the circular track at all times? please refer to the attached file for a diagram.
thnx
ty
Think in conversation of total energy, at the point where the car is supposed to have the lowest value of velocity in the circular track..
doesnt the velocity remain the same? or does it change due to gravity?
this is confusing
ty
indeed not, did u ever threw a ball in the air and it kept going up?
what's the potential energy of gravity?
what do you think of total energy at each point of the track, even during the circular part?
what are the two special cases regarding kinetic energy and potential energy here?
isnt PE = mgh?
im not sure if i am making this more complicated
or is there anything to do with circular motion?
ty
at each point of the track there is a conservation of total energy
Et=Kinetic + Gravity
Et=1/2mv^2 + mgh
if r is max, at the highest point of the track v equal what?
what does h equal regarding r?(if we take the flat part of the track the level where potential energy equal 0)
I have to go now, I have an exam in less then 2 hours.
again I tell you think of conservation of total energy at 2 distinct point of the track..
so i would substitute 4m/s into the v part of the equation?
ty
ok
i will try
thnx
as ziad1985 has mentioned before, this situation can be solved by using the formulas of P.E. (potential energy) and K.E. (kinetic energy)
[tex] \begin{array}{l}<br /> P.E. = mgh \\ <br /> K.E. = \frac{{mv^2 }}{2} \\ <br /> \end{array}[/tex]
now you need to make these two equations equal to each other, as the kinetic energy of the car at the base of the circular path would be equal to the potential energy at the top (conservation of energy)
[tex]mgh = \frac{{mv^2 }}{2}[/tex]
now by manipulating that equation you can get it ion terms of r (radius of the circle)
assuming h to be the diameter of the circle (2r)
[tex] \begin{array}{l}<br /> mgh = \frac{{mv^2 }}{2} \\ <br /> 2mgh = mv^2 \\ <br /> m\left( {2gh} \right) = mv^2 \\ <br /> 2gh = v^2 \\ <br /> h = 2r \\ <br /> 2g\left( {2r} \right) = v^2 \\ <br /> 4gr = v^2 \\ <br /> \frac{{v^2 }}{{4g}} = r \\ <br /> g_{acceleration} = 9.8\,m\,s^{ - 2} \\ <br /> \frac{{4^2 }}{{4\left( {9.8} \right)}} = 0.4081 \\ <br /> \end{array}[/tex]
so the maximum radius of the circle is 0.4081 meters, any larger the energies would not be equal and the car will leave the track
thnx a lot
can u help me with my other problems?
ty
other problems?
  • · Replies 19 ·
