Thread Closed
Inequality
Share Thread
Mar8-07, 04:05 AM   #1
Inequality
[tex]
\left| {2x + 1} \right| \ge \left| {x - 3} \right|
[/tex]
Now, i must solve for x. I could easily do it by graphing it on my calculator, and get an answer of [tex]x \le - 4,x \ge \frac{2}{3}[/tex].
How can i do it algebraically?
Thanks in advance,
Dan.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar8-07, 04:50 AM   #2
Math 2012
Recognitions:
You could start by finding the points where |2x+1| = |x+3|
You can get rid of the absolute values by squaring each side.
Mar8-07, 05:24 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Agreed. The best way to solve most inequalities is to solve the associated equation first. For continuous functions such as absolute value, the places where they are equal are the only places where the inequality can change so you need check only one point in each interval between solutions of the inequality to see whether the inequality is true or false there.
Another way of solving an absolute value equation is to consider whether the quantity inside is positive or negative. If 2x+1 and x+3 are both negative or both positive then 2x+1= x+ 3. If they are of different sign then 2x+ 1= -(x_ 3). After solving check to make sure the signs are right for that point.
Mar8-07, 06:14 AM   #4
Inequality
ok solving the equation, i get x=2/3, x=-4. So would i pick any 'test' value in between these points, and find weather the inequality is true or false?
Using zero, the inequality is false. So that would mean that x is outside of the solutions, less than -4, but greater than 2/3? Is that the reasoning i should be using to attack these problems?
Thread Closed
Similar discussions for: Inequality
Thread Forum Replies
solve the following equation x^2 – x < 0 General Math 2
Prove for all a,b,c>0: a/(b+c) + b/(a+c) + c/(a+b) >= 3/2 ? General Math 1
Need help with an inequality. Precalculus Mathematics Homework 4
Inequality Precalculus Mathematics Homework 4
Proof this inequality using Chebyshev's sum inequality Calculus & Beyond Homework 1
