Solution to Capacitor Problem: q=12uC, V=4V
  • Thread starter Thread starter 21385
    Capacitor
The problem involves a 3uF capacitor initially charged to 12V and then connected in parallel with an uncharged 6uF capacitor. Participants are discussing the charge and potential difference across the capacitors at equilibrium.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are examining the initial and final conditions of the capacitors, questioning the meaning of the capacitor being "not connected to anything," and discussing how to calculate the final voltage and charge after connection.
Some participants have provided guidance on using the equations for charge and capacitance to analyze the problem. There is an ongoing exploration of the implications of the initial conditions and how they affect the final state of the capacitors.
There is a mention of the need to avoid providing exact answers, emphasizing the forum's focus on guiding understanding rather than solving the problem outright.
21385
The potential across a 3uF capacitor is 12V when it is not connected to anything. It is then conntected in parallel with an uncharged 6uF capacitor. At equilibrium, the charge q on the 3uF capacitor and the potential difference V across it are
a)q=12uC, V=4V b)q=24uC, V=8V
c)q=36uC, V=12V d)q=12uC, V=6V
q=CV
Parallel connections
C(total)=C1+C2
The answer is a) but I am not sure why. The first part of the question confuses me. I don't really know what it means when they say that it is not connected to anything. Thanks.
Write the equation Q=CV for the initial situation, and then for the final situation. The initial situation is just the 3uF cap charged to 12V. The final situation is as you indicate, with the total capacitance the sum of the two caps. What is the final voltage across the two caps? Use that final voltage, which is across both the 3uF and 6uF capacitors now, to calculate the final charge that is on the 3uF cap.
The common potential across both the capacitors after connection is given by
<< exact answer deleted by berkeman >>, i.e. total charge upon total capacitance. And for the first part I assume it means that it was charged by connecting to a battery, after which the battery is removed thereby making the charge accumulated on the plates of the capacitor constant.
<< exact answer deleted by berkeman >>, i.e. total charge upon total capacitance. And for the first part I assume it means that it was charged by connecting to a battery, after which the battery is removed thereby making the charge accumulated on the plates of the battery constant.
shramana, please do not post exact answers to homework questions. Our task here is to provide tutorial help, not the answers. That is stated clearly in the PF rules.
Thank you guys!
  • · Replies 18 ·
