Hartley Oscillator: Advantages & Disadvantages
  • Thread starter Thread starter Jdo300
    Oscillator
The discussion centers on the advantages and disadvantages of Hartley oscillators, particularly focusing on their harmonic content and suitability for generating pure sine waves. Participants explore the implications of using different active devices, such as transistors versus vacuum tubes, and consider alternative oscillator designs for specific frequency ranges.
  • Experimental/applied
  • Some participants note that disadvantages of Hartley oscillators include harmonic-rich output and unsuitability for pure sine wave generation.
  • One participant suggests that harmonics originate from the active device in the circuit, questioning whether using a vacuum tube would reduce harmonic content.
  • Another participant argues that tubes may not necessarily reduce harmonics and mentions that different devices produce different harmonic characteristics.
  • It is noted that the positive feedback loop in Hartley oscillators, which uses a coil voltage divider, may contribute to a broader frequency response compared to capacitive feedback in Colpitts oscillators.
  • One participant mentions that for VHF applications, JFET transistors can produce cleaner signals than BJTs, and that oscillators often require filters to eliminate unwanted frequencies.
  • There is a question about the impact of harmonics when operating in the ULF to LF frequency range, with one participant indicating that harmonics would still be present but may be less concerning.
  • Another participant warns about the impracticality of building a Hartley oscillator for ULF due to the size of the coil required.
  • Suggestions are made to consider Colpitts oscillators for their simplicity and ease of tuning, although frequency tuning would still depend on the inductor.
  • A participant proposes that harmonics can be mitigated by using a buffer amplifier and a passive filter circuit, emphasizing the importance of good decoupling and board design.
Participants express differing views on the sources of harmonics and the effectiveness of various oscillator designs. There is no consensus on the best approach for minimizing harmonics or the practicality of using Hartley versus Colpitts oscillators for specific applications.
Participants discuss the limitations of Hartley oscillators in terms of harmonic output and practical construction challenges, particularly at lower frequencies. The discussion includes considerations of device choice and circuit design that may affect performance.
Individuals interested in oscillator design, particularly in the context of electronics experiments or applications involving frequency generation in various ranges.
Jdo300
Hello All,
I was just reading an article on Wikipedia about Hartley Oscillators and they mention this at the bottom of the page:
Disadvantages include:
* Harmonic-rich content of the output
* It is not suitable for a pure sine wave
I'm assuming that the harmonics are coming from the transistor in the circuit? Could this be solved if a vacuum tube were used instead of a SS device?
Thanks,
Jason O
Harmonics ALWAYS come from the active device in the circuit. I don't think that a tube will reduce the harmonics. Tubes typically have different harmonics than transistors do though. I don't recall which is which, but one has more energy in the odd harmonics and the other more in the even harmonics.
In a hartley oscillator, the positive feedback loop runs through a coil voltage divider, as opposed to a capacitive feedback loop in a colpitts oscillator. Most inductors have a lower Q compared to a capacitor, as a result they are less selective and susceptible to a broad frequency response in a LC circuit.
But the number one cause of harmonic content is the transistor itself. Different biases and configuration will result in different harmonics. For VHF, a Jfet transistor produces a much cleaner signal than BJT transistor. In either case, oscillators are usually followed by notch or low pass filters to kill unwanted frequencies.
Thanks guys for the replies. I'm interested in building one of these for some experiments I'm doing. Now, concerning the harmonics, would they be as bad if the oscillator is running in the ULF to LF frequency range? Also, for the simplest versions of this oscillator (like the one pictured on Wikipedia, what kind of tuning range can one get with one of these?
Thanks,
Jason O
Same thing for ULF (ultra low frequencies) would still have the same harmonics. But its impractical to build a Hartley oscillator for ULF as the coil would have to be a mile long.
I wouldn't worry much about harmonics, the next closest harmonic would be down by 20 to 30 dB at least anyways.
If you building the oscillator, I would recommend you build the Colpitts one. Because you only need one coil, and the capacitive feedback loop would be easy to tweak. Frequency tuning would have to be done by tuning the inductor though.
As for the frequency range, the higher the frequency of operation the more frequency tuning leeway you will have, before the feedback loop dies.
Hi, thanks for the tip. Would a Colpitts oscillator be practical for the frequency range that I am working with? Or is there some other oscillator scheme that is better suited for the frequency range I'm working with (100 Hz to 1 MHz roughly). I don't know much about them.
Harmonics can be avoided if you couple the output of osc with a buffer-amp together with a passive filter circuit (with low-tolerance resistors and high order of the filter) Good decoupling and board design will give improved results.
  • · Replies 21 ·
11K
  • · Replies 19 ·
11K
  • · Replies 20 ·
